  1. As you can see in the picture how do I do exactly the same ? Name:  Screenshot_1.jpg
  2. Something like
    [Attachment 50533 - Click to enlarge]
    Just Arial font. Made and exported from Subtitle Edit.
  3. I tried with the application, but it wasn't exactly the same, Is there another application or setting that can do exactly the same.
    canada
    Try easysup,it makes blu-ray subtitles from srt.
  5. Member Ennio's Avatar
    May 2005
    Netherlands
    You can also do this with SubtitleEdit.
