I truly hope that someone will be able to assist me with this one.
Here is my dilemma:
I use DVDFab to copy discs, but have never had this type of struggle before. I have copied 5 discs out of a 6 set collection, but one of them will not read with DVDFab! Meaning, when I insert the disc into my computer to copy it, NOTHING occurs. Usually DVDFab will begin to read the disc before the copy process. The disc is not scratched or smeared, either. If I have an occasional issue, I will use water to clean the disc.
What do you think is going on here?
Results 1 to 13 of 13
does the disc show up when you click on your computers dvd drive ??
Well wherever you read, or thought, it was a clever idea to clean a disk with water.....
You have killed your disk. -
I have not "killed" the disc. I have cleaned many discs with water and were able to copy with DVDFab. I cleaned the other 5 discs in the collection, and they copied just fine.
The problem is the disc itself. It will not play in the DVD player. It say says that it Cannot Operate Disc. -
LOL soap and warm water has always been an acceptable method of cleaning plastic cd/dvd's. they are sealed. and unless dropped on edge usually remain that way. if it was open you'd notice the dye deteriorating inside.
look closely at the dye side. if there is any variation in color the disc may have died. they all do sooner or later, and cheap discs are not lasting nearly as long as projected for the dvd standard.--
AFAIK, water will not harm either a DVD or CD (they are manufactured quite differently). You might do damage to the label, but that's all.
Dual sided laserdiscs were bonded together with glue (which was a contributing factor to "laser rot"), but I'm not sure that even that would be damaged by casual water exposure.
I've cleaned lots of discs using various cleaning agents, usually Cinch. No problems. -
Ok. Fairy Nuff.
I have since read that a solution of alcohol and water can be used. That same article does also mention warm water.
But what went through my pea-brain was a situation where the cleaning was not fully dry and could have damaged the surface by the laser.
Maybe I have been lucky or just careful. But I have NEVER had to clean a single disk. -
The question was...
But to elaborate.
Has the 6th disk worked before in any playback scenario ? -
Some drives won't read some discs. Simple as that. Try it in a different computer and odds are it'll load right up.
PC writing a DVD_RTAV folder back to DVD-RAM disc so Panny can read it ?
By DBenz in forum Newbie / General discussionsReplies: 6Last Post: 1st Feb 2018, 10:21 -
Why can't DVDFab rip/see all episodes on my retail DVD-DL disc ?
By Subzero11 in forum DVD RippingReplies: 11Last Post: 19th Aug 2017, 11:13 -
Fix: "The tray is being operated or a disc is being read" Sony BluRay USB
By Doogy2Shox in forum DVD & Blu-ray PlayersReplies: 0Last Post: 29th May 2017, 06:54 -
M-DISC, Write Once and Read Forever?
By Nice2BHi in forum MediaReplies: 28Last Post: 16th May 2017, 13:02 -
Can't read DVD data disc on XP
By AlanHK in forum ComputerReplies: 3Last Post: 4th Sep 2015, 23:05
