Hi all - new here today, but used to look at the vcdhelp.com about 15 years ago and found it very helpful.
I'm looking for advice on a network media player or NAS set up that I can rip my DVD / Blu-Rays to so that I can access them from my Smart TV.
I want to be able to rip the movies and keep the chapter / navigation points. The initial menu and chapter choice would be great too (I'm not bothered by extras). Almost like using the old DVD Decrypter / DVD Shrink but putting it on the network to be accessed by the TV.
I had a quick skim of the threads but couldn't obviously see anything - if anyone could post a couple of links that would be great.
Justin
	TVs don't understand how to use the DVD files and folder structure or the Blu-ray files and folder structure so you can't keep the menus.
 Check your TV manual to see if it will play MKV files and how it expects subtitles to be presented for MKV. MakeMKV can produce you an MKV with the chapter points. I haven't yet seen any Smart TV media players that are able to display SUP or PGS subs, which means if you want subtitles, you will probably need to convert them from their native SUP or PGS format to SRT. Many TVs also want the subtitles in the same folder with the MKV file and not muxed into the MKV.Ignore list: hello_hello, tried, TechLord, Snoopy329
	JustinUK-In the future use a more descriptive title rather than 'newbie here,help me" etc.I changed the title this time. I think,therefore i am a hamster.
	It's true that an HTPC would provide more versatility and reliability than a smart TV's media player, but there are still problems connected with playing Blu-ray rips with menus. There are some free or lower-cost unlicensed software players for playing Blu-ray but they don't provide complete access to Blu-ray menus. Unfortunately, complete access to Blu-ray menus requires more expensive paid software, like PowerDVD Ultra or Corel WinDVD Pro.
 I have used a smart TV with DLNA capability for playing files stored on a network-connected PC. It can work, but the container file type must be supported and the video, audio, and subtitles may need to be converted to match what the TV will accept.Last edited by usually_quiet; 13th Oct 2019 at 16:25. Ignore list: hello_hello, tried, TechLord, Snoopy329
	i use chromecast or firetv devices hooked up to smart tvs, as all tvs are as dumb as a box of rocks when it comes to playing video files. even with those networked devices i install vlc on them to be the actual video renderer. vlc has network access and can play files off any "shared" local network device. even so i rip all blurays and dvds to "movie only" for compatibility. --
	I use my ps3 to play my mkv files with no issues. I think,therefore i am a hamster.
	Another matter to consider is audio. Even if a tv could process blu-ray disc-structures and/or read mkv files, you may run into issues when you want to play tracks that contain later generation formats that may have lossless high resolution audio, Dolby Atmos, DTS:X etc.
 Chances are that your tv will not be able to decode those and/or to forward the bitstream to a HDMI receiver.
 When you use something like Plex you can configure the audio output in the settings.
 Buying a separate network-mediaplayer is IMO the best solution in case you want to be able to play the latest audio formats via a surroundreceiver (that has support for these audio formats, of course). Especially for non-4K content they are cheap nowadays.Last edited by Ennio; 14th Oct 2019 at 19:33.
  media player with network access to connected usb hdd?By elterry in forum Media Center PC / MediaCentersReplies: 13Last Post: 20th May 2019, 12:54
  Still seeking media player network access connected usb hdd. NOT streamingBy elterry in forum Media Center PC / MediaCentersReplies: 1Last Post: 14th Mar 2019, 04:00
  Streaminh Video from Network drive to BD player adviceBy efiste2 in forum Media Center PC / MediaCentersReplies: 4Last Post: 20th Aug 2016, 17:26
  How to stream media files from NAS to tv without using pc?By Denvers Dawgs in forum Newbie / General discussionsReplies: 2Last Post: 9th Feb 2016, 07:11
  IPTV Set-top box vs HD TV Media PlayerBy siluet in forum DVB / IPTVReplies: 1Last Post: 5th Dec 2014, 20:27
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
