[Attachment 50477 - Click to enlarge]
Do you think this kind of dirt can be cleaned? I've looked up Descratch, but it seems to be only for large vertical/horizontal scratches, and RemoveDirt but I had no success with it. The script is quite complex so maybe it can be fine tuned to work on something like that I don't know. Those marks look too difficult to remove but I thought I might as well ask, since some plugins are really able to work small miracles![]()
Probably; but it depends on the characteristics. If it's static, doesn't move, then it's usually more difficult.
In general, removing dirt is "easy" . It's keeping details or not causing too much damage is that is the hard part
If you post a video sample someone will suggest something -
Dirt (literally dirt or other damage on the film) that appears on only one frame (you may have to IVTC first) can be removed with RemoveDirt(). Dirt, dust, hair that's in the projector may appear on many consecutive frames and is harder to remove. How is a program to know what's unwanted dirt vs. what's an actual detail of the movie?
If it doesn't move around you can infill the area with a delogo filter. Like this one for VirtualDub:
http://rationalqm.us/delogo132/delogomanual/delogo.htm
VirtualDub filters: Film Dirt Cleaner, Intelligent Brightness, deshaker(?)
By calmkeeper in forum RestorationReplies: 2Last Post: 23rd Feb 2022, 17:21 -
DVD with hidden chapter marks? (subchapters)
By TechLord in forum Authoring (DVD)Replies: 3Last Post: 30th Sep 2017, 18:22 -
How to accurately split a video with custom chaper marks?
By LoverOfLove in forum EditingReplies: 2Last Post: 10th Dec 2016, 22:01 -
Dirt removal in Virtual Dub
By timsky in forum RestorationReplies: 34Last Post: 22nd Jun 2016, 23:18 -
Removing these pesky marks - a.k.a what am I doing wrong in green-screening
By blazingweb in forum EditingReplies: 2Last Post: 1st Jan 2015, 09:12
