We appreciate that but means I will need to learn to do this on my pc then install ffmpeg on her pc and show her how to do it or do it myself.
I am willing to try to help her out, I will not be charging her for this but first issue is if you can refer to my post #10 please, I am not able to install or open the ffmpeg utility?
Results 31 to 60 of 69
ffmpeg is a commandline tool, which mean you cannot open it with a double click. But don't worry, I help you:
You have downloaded the latest ffmpeg.exe from videohelp, right?
Open Notepad paste the Code from @jagabo, one of the best persons here on videohelp
Then save the text file as test.bat or what you want, the .txt must be replaced with .bat
Place also the ffmpeg.exe in the folder with the bat file and the videofiles
doubleclick the bat file -
I followed this tutorial to the letter : https://www.youtube.com/watch?v=xcdTIDHm4KM
So according to that ffmpeg is instaeed. Assuming that is accurate, I go to START, then type ffmpeg which shows ffmpeg.exe but when I click on that it opens a cmd window only for a split second so what can I do next please? I think I am understanding now, I was looking for a Utility with a GUI but seems the "command line" which you guys are referring to is having to work inside of a cmd instead? -
1) Start Notepad.
2) Copy/paste the lines in the code box in post #28.
3) File -> Save with Notepad -- when you enter the filename include the extension .bat so Notepad doesn't save with the default extension .txt. For example type "RemuxAll.bat" as the file name (without the quotes) Be sure to save the bat file in the folder with your swf files (or move it there if you've already saved somewhere else).
4) Use Explorer to navigate to the folder with the swf files. Double click on the bat file. You can delete it when you're done.
Note that this requires that ffmpeg.exe be in the search path. Or you can specify the entire path to ffmpeg.exe in the batch file. If you don't understand what all this means -- just put a copy of ffmpeg.exe in the same folder as the batch file. -
Sorry flashandpan007, looks like we had both posted at the same time.
Jagabo, copy/paste both codes in post#28 into notepad? -
What about the SAVE AS TYPE, the default is .txt or should I save as ALL FILES option please?
Done, I am seeing the RemuxAll.bat file plus the ffmpeg.exe file in the folder with the swf files on the external drive .
I just double-clicked the bat file and seeing the cmd doing something
command line tools are perfect for doing the same thing for a very large number of files
Just wait until it is finished, new files already showing up? -
Yes new files are showing with the extension .mp4. This might take a long time I guess.
Hey guys, all looks well. Got 170 swf and 170 mp4 files in the folder and playing well it seems. Just one last question please, which is the best free video player you can recommend for these files?
Yeah I too was thinking VLC would be the best option for these files for her, thanks.
Well guys, Sophya's exact words to describe you guys was "these guys are awesome". So I wish to thank you all very much for all of this help, I just said a prayer for you all, God bless you guys! Till next time, all the best, Mike and Sophya. -
Thanks, I guess she can try all 3 mentioned to see which one will work best for her.
Hey guys, I have similar situation here with swf files not playing after the data recovery. I tried copying the steps in this thread, please see attached pics and tell me what I am doing wrong?
I opened notepad and copied the code from post #36 above into it:
for %%F in (*.swf) do (ffmpeg -y -i "%%F" -codec copy "%%~dpnF.remuxed.mp4")
pause
saved it as RemuxAll.bat into the folder with the files. Put the ffmpeg.exe file in the folder. Renamed the extension of each swf file to .mp4 and double clicked the notepad file [RemuxAll.bat] which opens the cmd but when I hit any key the window dissapears. -
Scroll the CMD window up so we can see the actual command line that was executed.
Just for clarification, the only thing I am supposed to put into Notepad is this code below, right?. Aside from that I cannot see that I have done anything outside of the instructions
pause -
Yes, the contents of your batch file is correct. And ffmpeg is getting the correct commands. It looks like ffmpeg is just having a problem reading your swf files. Do they play properly on your computer? Can you upload a small one for testing? (You may have to ZIP the swf file if you upload it here. I don't think the site accepts SWF files.)
The files play in VLC meaning I can see the timer working as a normal file would and I can see the length of the file but blank screen, no video. The owner of the files said they are a slideshows of images. They are too large to upload here, maybe tomorrow I can upload to google drive or drop box, let me know which would work best please?
This is what I am seeing when I import one of the files into Media info.
Ok, any idea then what I might try to get the files to show please?
Playing vector based SWF files
By Greatminty in forum Video ConversionReplies: 10Last Post: 18th Feb 2018, 13:45 -
Need help with Mplayer to play mov files which reference to external files
By Selur in forum Newbie / General discussionsReplies: 0Last Post: 2nd Dec 2017, 13:21 -
Is there any media player that plays FLV or SWF files form Youtube?
By peggypwr1 in forum Newbie / General discussionsReplies: 14Last Post: 13th Nov 2015, 01:55 -
DVD video doesnt play. VOB files play fine. How do i remake DVD?
By chrisie in forum Newbie / General discussionsReplies: 2Last Post: 7th Jul 2015, 15:48 -
[SOLVED] Can't download SWF video
By yetanotherlogin in forum Video Streaming DownloadingReplies: 2Last Post: 17th Oct 2014, 12:03
