I'm trying to download a stream from a paid sports site but haven't find a way to. There is no .m3u8, no manifest, no .ism. Just a bunch of .m4f files. Here's how the link to the .mpd dash looks like:
https://ncdn-catchup-ssl.pfd.sfr.net/out/vod/dash/c/2da/RMS5342666/RMS5342666.mpd
The site I'm trying to download from is rmcsport.tv. It's unfortunately behind a paywall so I don't know if anyone can figure out how to download just off of my info. Note that Video DownloadHelper shows a bunch of .mp4 and audio files.
I'd appreciate any help. Thanks.
Results 1 to 10 of 10
That'd be risky for me because you'd have access to my account and would be able to charge my account for stuff... Rather, I'm trying to see if the User-Agent Switcher + The Stream Detector could work, but I'm not able to click when I choose User Agent Apple iOS. Do you know how I can click? I've tried using Ctrl + Shift + M while in iOS User Agent, but still not able to click. Thanks.
So... are you saying you were able to download it? Can you guide me through please? Thanks.
You can get HLS for this instead, i just played around.
So in the link:
you see a part called /dash/. I tried renaming it to /hls/ and then tried renaming the stream fiile to .m3u8 and voala:
This m3u8 will have all kinds of resolutions,including 1080p i think.
Now all you need to do this use youtube-dl or streamlink to capture the video
orstreamlink.exe "https://ncdn-catchup-ssl.pfd.sfr.net/out/vod/hls/c/2da/RMS5342666/RMS5342666.m3u8" best -o video.ts
You're welcome.youtube-dl.exe "https://ncdn-catchup-ssl.pfd.sfr.net/out/vod/hls/c/2da/RMS5342666/RMS5342666.m3u8" -
Thank you so much!
Wow, all that was required was changing things up a bit... Who'd have thought it? Anyway, thanks again for your help.
Hello,
I used the trick above and downloaded with youtube-dl, to no avail.
Is it definitely off-limit with youtube-dl?Code:c:\>youtube-dl.exe https://lil1-cdn-edge-vod00.pfd.sfr.net/ncdn-cu-kairos-lyo0.pfd.sfr.net/sid=01rrpvedvh7i22sbca80/dashcenc/catchup/NEUF_BFMTV/51c/WFM1_BFM3085238/manifest.mpd [generic] manifest: Requesting header WARNING: Falling back on generic information extractor. [generic] manifest: Downloading webpage [generic] manifest: Extracting information ERROR: No video formats found; please report this issue on https://yt-dl.org/bug . Make sure you are using the latest version; type youtube-dl -U to update. Be sure to call youtube-dl with the --verbose flag and include its complete output. c:\>youtube-dl.exe -F https://lil1-cdn-edge-vod00.pfd.sfr.net/ncdn-cu-kairos-lyo0.pfd.sfr.net/sid=01rrpvedvh7i22sbca80/hls/catchup/NEUF_BFMTV/51c/WFM1_BFM3085238/manifest.m3u8 [generic] manifest: Requesting header WARNING: Could not send HEAD request to https://lil1-cdn-edge-vod00.pfd.sfr.net/ncdn-cu-kairos-lyo0.pfd.sfr.net/sid=01rrpvedvh7i22sbca80/hls/catchup/NEUF_BFMTV/51c/WFM1_BFM3085238/manifest.m3u8: HTTP Error 404: Not Found [generic] manifest: Downloading webpage ERROR: Unable to download webpage: HTTP Error 404: Not Found (caused by HTTPError()); please report this issue on https://yt-dl.org/bug . Make sure you are using the latest version; type youtube-dl -U to update. Be sure to call youtube-dl with the --verbose flag and include its complete output. c:\>youtube-dl.exe -F https://lil1-cdn-edge-vod00.pfd.sfr.net/ncdn-cu-kairos-lyo0.pfd.sfr.net/sid=01rrpvedvh7i22sbca80/hls/catchup/NEUF_BFMTV/51c/WFM1_BFM3085238/manifest.mpd [generic] manifest: Requesting header WARNING: Could not send HEAD request to https://lil1-cdn-edge-vod00.pfd.sfr.net/ncdn-cu-kairos-lyo0.pfd.sfr.net/sid=01rrpvedvh7i22sbca80/hls/catchup/NEUF_BFMTV/51c/WFM1_BFM3085238/manifest.mpd: HTTP Error 404: Not Found [generic] manifest: Downloading webpage ERROR: Unable to download webpage: HTTP Error 404: Not Found (caused by HTTPError()); please report this issue on https://yt-dl.org/bug . Make sure you are using the latest version; type youtube-dl -U to update. Be sure to call youtube-dl with the --verbose flag and include its complete output.
Thank you. -
Use ytdlp
However, content is encrypted, and you'll have to use Guesser to get keys for decryption, use mp4decrypt to decrypt and ffmpeg to mux video and audio.Code:ytdlp.exe --allow-u "https://lil1-cdn-edge-vod00.pfd.sfr.net/ncdn-cu-kairos-lyo0.pfd.sfr.net/sid=01rrpvedvh7i22sbca80/dashcenc/catchup/NEUF_BFMTV/51c/WFM1_BFM3085238/manifest.mpd"
Read this sub-forum more. -
Thanks, I'll read up on Guesser and mp4decrypt
https://github.com/Satsuoni/widevine-l3-guesser
Edit: As an easier work-around, I simply recorded the screen with OBS.Last edited by yetanotherlogin; 20th Nov 2021 at 05:53.
Need help downloading a DRM .mpd manifest
By fuzzco in forum Video Streaming DownloadingReplies: 4Last Post: 25th Mar 2022, 22:08 -
how to download video files with "mpd" (mpeg dash manifest)?
By nzhd in forum Video Streaming DownloadingReplies: 59Last Post: 17th Apr 2021, 05:26 -
Downloading mpd stream (DRM protected?)
By odyssey1234 in forum Video Streaming DownloadingReplies: 8Last Post: 14th Aug 2019, 21:26 -
Problem with [MPD] (mpeg dash manifest) - HRTi
By SamoMalo404 in forum Video Streaming DownloadingReplies: 0Last Post: 20th Jan 2018, 23:02 -
how to obtain the url from manifest.mpd
By gigio in forum Video Streaming DownloadingReplies: 4Last Post: 29th Dec 2017, 18:33
