I was looking at it in VDub, using the bob doubler filter. The reason I looked at it in the first place is my output x264 file didn't look right playing back on my TV:
ffmpeg.exe -i "converttoyv12.avs" -vcodec libx264 -crf 18 -preset slow -pix_fmt yuv420p -force_key_frames 00:14:38.040,00:18:48.880,00:39:17.240,01:07:32.24 0,01:10:50.560,01:14:10.480,01:32:59.320 -aspect 16:9 -x264opts level=4.1 "video.264"
Results 61 to 71 of 71
VirtualDub does not display interlaced YV12 correctly. It treats the interlaced chroma as progressive, screwing up the colors of the two fields.
[Attachment 59650 - Click to enlarge]
On the top is the proper display with AssumeTFF().Bob() in AviSynth. On the bottom is the way VirtualDub displays it with BobDoubler.Last edited by jagabo; 1st Jul 2021 at 07:33.
That's a generally weird shot with blurry edges of the frame, lens flare, and irregular frame duplicate pattern. But there's no obvious problem with the chroma.
You encoded progressive for the sample, and according to post 61
(and you have 5 reference frames for 1920x1080p25, which is "illegal" for L4.1, but you set -x264opts level=4.1 - this can cause problems with older chips and hardware in terms of other playback problems such as stuttering) -
Oops, I cut the wrong sample. It was supposed to be the same shot as before. Here it is.
The earlier sample is from a clip within the game that was frame-blended for some reason. They do that with highlight clips and location shots. No idea why.
The game itself is interlaced, although now that you mention it...my ffmpeg command line doesn't include anything about interlacing, does it? -
x264opts tff=1
Many TV's ignore colorimetry flags, but it doesn't hurt to flag it 709 either
Force ref=4, otherwise don't use L4.1 at all. The Level parameter is not enforced, it's just a "label"
Code:-x264opts level=4.1:ref=4:tff=1:colormatrix=bt709
Yes, you encoded the interlaced video progressive. You need to encode it interlaced.
I have an "interlaced" template and a "progressive" template, obviously I copied-and-pasted the wrong one.
I'd have picked it up immediately except that it didn't comb, at all. Which I'd expect progressive video to do. Weird.
File type don't work
By lostsoul65 in forum Newbie / General discussionsReplies: 3Last Post: 5th Jan 2019, 16:46 -
is the mp3 file corrupt ('I Don't Believe)?
By blümchen in forum AudioReplies: 4Last Post: 20th Nov 2016, 01:51 -
What is wrong with this MPEG-1 file?
By koozmusic in forum Software PlayingReplies: 21Last Post: 16th Feb 2016, 21:48 -
1st 12 min. of srt subtitles don't show up in VOB file film - how to repair
By Videosub in forum Video ConversionReplies: 6Last Post: 6th Aug 2015, 10:02 -
De-interlacing help for HD file captured from Satellite TV
By nharikrishna in forum EditingReplies: 65Last Post: 23rd Nov 2014, 11:08
