I am wondering if anyone else has experienced this.
I have audio that I am placing in a video that I am editing via VSDC and I want to add "pitch shift" effect as well as a little "reverb". I can add one or the other and each effect works as it is supposed to. When I try to add both I get nothing. As if the sound has all together been cancelled out. I have tried this with multiple effects and it seems like it just doesn't like two effects on the same track. Is this for real?
Thanks in advance,
Willy
It's not important the problem be solved, only that the blame for the mistake is assigned correctly
VSDC - multiple movement animations not working in Export
By David328 in forum Newbie / General discussionsReplies: 3Last Post: 17th Oct 2021, 17:55 -
VSDC Free Video Editor: align multiple video on timeline
By kj1983 in forum EditingReplies: 0Last Post: 15th Sep 2017, 23:49 -
Set and save multiple selections on an audio track
By glvid in forum AudioReplies: 12Last Post: 16th Apr 2016, 07:15 -
Adobe After Effects CC - Importing multiple videos without merging?
By LienFilm in forum Newbie / General discussionsReplies: 3Last Post: 2nd Sep 2015, 10:50 -
How to get the track of sound effects and the music from Ac3 & DTS audio ?
By Abdo in forum AudioReplies: 2Last Post: 19th Oct 2014, 07:10
