I have a script below which was done for me to blur subtitles, using ffmpeg. is there a way to make the blurred subtitles more fine. like smoother. if so what is needed in this script or can be added
Code:@setlocal @echo off @echo "delogo parameters script" @set xx="Unknown" @set yy="Unknown" @set ww="Unknown" @set hh="Unknown" @rem folder where ffmpeg.exe is located @set FF=C:\ffmpeg-3.4-win64-static\bin @set PATH=%FF%;%PATH% @set filename=%~1 @rem video quality settings @set vq=25 @rem audio bitrate @set ab=192 :new @cls @echo . @echo . @echo Old delogo=x=%xx%:y=%yy%:w=%ww%:h=%hh% @echo . @echo . @rem delogo filter settings @set /p xx="Enter X - the top left corner coordinate of the subtitle: " @set /p yy="Enter Y - the top left corner coordinate of the subtitle: " @set /p ww="Enter W - the width of the subtitle to clear: " @set /p hh="Enter H - the height of the subtitle to clear: " @cls @echo . @echo . @echo delogo=x=%xx%:y=%yy%:w=%ww%:h=%hh% @echo . @echo . @echo "Are you OK with above delogo filter parameters" @choice /c:yn /M "Press Y for Yes to preview, N for No and return to start." @if errorlevel 2 goto new @if errorlevel 1 goto start :start @ffplay.exe -hide_banner -v 32 -stats -autoexit -i %filename% -an -vf "setpts=PTS/5,delogo=x=%xx%:y=%yy%:w=%ww%:h=%hh%:show=1" @echo . @echo . @echo "Start ffmpeg with delogo filter parameters?" @echo . @echo . @choice /c:yn /M "Press Y for Yes to continue, N for No and return to start." @if errorlevel 2 goto new @if errorlevel 1 goto selenc :selenc @echo . @echo . @echo "Please select encoder - Slow but higher qaulity press Yes or Fast but lower quality No" @echo . @echo . @choice /c:sf /M "Press S for SLOW or F for FAST encoder" @if errorlevel 2 goto ffast @if errorlevel 1 goto sslow :sslow @cls @echo . @echo "ffmpeg libx264 begin encode with delogo=x=%xx%:y=%yy%:w=%ww%:h=%hh% parameters" @echo . @SET x264opts="crf=%vq%:level=4.0:qpmin=8:vbv_maxrate=20000:vbv_bufsize=10000:ref=3:bframes=3:rc-lookahead=32:cabac=1:interlaced=0:no_psnr=1:no_ssim=1:bluray_compat=1:open-gop=0:pic_struct=1:aud=1:nal_hrd=vbr:force_cfr=1:overscan=show:colorprim=bt709:transfer=bt709:colormatrix=bt709" @set aproc="pan=stereo|FL < FL+1.414FC+0.5BL+0.5SL+0.25LFE|FR < FR+1.414FC+0.5BR+0.5SR+0.25LFE,dynaudnorm=p=1/sqrt(2):m=100:s=20" @set vproc="pp=ac,delogo=x=%xx%:y=%yy%:w=%ww%:h=%hh%,scale=iw:ih:sws_flags=spline+accurate_rnd+full_chroma_int+full_chroma_inp:interl=-1:out_range=auto:out_color_matrix=bt709,format=pix_fmts=yuv420p" @ffmpeg.exe -hide_banner -v 32 -stats -y -i "%filename%" -vf %vproc% -c:v libx264 -preset faster -tune film -profile:v high -level:v 4.0 -x264opts %x264opts% -x264-params %x264opts% -af %aproc% -c:a ac3 -b:a %ab%k -f matroska "%~n1_delogodynaudio.mkv" goto end :ffast @cls @echo . @echo "ffmpeg NVEnc begin encode with delogo=x=%xx%:y=%yy%:w=%ww%:h=%hh% parameters" @echo . @set aproc="pan=stereo|FL < FL+1.414FC+0.5BL+0.5SL+0.25LFE|FR < FR+1.414FC+0.5BR+0.5SR+0.25LFE,dynaudnorm=p=1/sqrt(2):m=100:s=20" @set vproc="pp=ac,delogo=x=%xx%:y=%yy%:w=%ww%:h=%hh%,scale=iw:ih:sws_flags=spline+accurate_rnd+full_chroma_int+full_chroma_inp:interl=-1:out_range=auto:out_color_matrix=bt709,format=pix_fmts=yuv420p" @ffmpeg.exe -hide_banner -v 32 -stats -y -i "%filename%" -vf %vproc% -c:v h264_nvenc -level:v 4.0 -preset:v hq -profile:v high -cq %vq% -qmin:v 8 -qmax:v 29 -bufsize:v 10000k -maxrate:v 20000k -g 250 -bf 3 -refs:v 3 -rc:v vbr_hq -rc-lookahead 32 -b_adapt 1 -temporal-aq 1 -spatial-aq 1 -i_qfactor 0.75 -b_qfactor 1.1 -coder:v cabac -bluray-compat 1 -aud 1 -aq-strength 8 -af %aproc% -c:a ac3 -b:a %ab%k "%~n1_delogdaudnv.mkv" goto end :end @echo terminating script @endlocal @timeout 30 @exit /b
Blurring background
By Fragha in forum SubtitleReplies: 0Last Post: 10th Jun 2018, 19:25 -
subtitle blurring
By natty in forum Newbie / General discussionsReplies: 81Last Post: 17th Oct 2017, 12:06 -
Recording video without blurring using Canon 550d
By Norma17 in forum Newbie / General discussionsReplies: 3Last Post: 10th Mar 2017, 12:55 -
Turning on subtitles is blurring the picture
By killerteengohan in forum Software PlayingReplies: 1Last Post: 25th Jul 2015, 20:26 -
Blurring Effect
By rmccam in forum EditingReplies: 8Last Post: 29th Jan 2015, 14:35
