Results 31 to 35 of 35
Avisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
Avisynth/VapourSynth functions CropResize - FrostyBorders - CPreview (Cropping Preview) -
Better compression and I noticed I got fewer artifacts. I did some test encodes with NVENC H265. Still doesn't beat x264 medium imo though. I have a GTX1070 card. The newer RTX 20 and RTX 30 series cards may be a different story.
The only problem with 10-bit H264 is that none of the hardware decoders, or none that I know of supported 10-bit decoding. So you were stuck with software decoding, and 10-bit software decoding took more power than the 8-bit. With H265 they seem to have had 10-bit in mind from the start.
AFAIK 10bit compression means smaller files:
- x265 - Always choose 10bit?
- QUICK COMPARE: AVC vs. HEVC, 8-bit vs. 10-bit Video Encoding
- Why does 10-bit save bandwidth (even when content is 8-bit)?
Is there any benefit by convert video from 8 to 16 bit ?
By alkoon in forum Video ConversionReplies: 2Last Post: 16th Jul 2019, 08:41 -
Is Rez or Bits More Important?
By Pareto Optimal in forum DVD RippingReplies: 8Last Post: 5th Jul 2018, 04:32 -
24 Bits 5.1 FLAC Lower kHz than 16 Bits Stereo FLAC?
By draig-llofrudd in forum AudioReplies: 5Last Post: 17th Dec 2016, 08:03 -
encode w/out the 'perception' benefit of x264 and x265
By vhelp in forum Video ConversionReplies: 9Last Post: 7th Nov 2016, 03:45 -
Will video processing benefit from a card upgrade.
By sambat in forum Video ConversionReplies: 3Last Post: 8th Oct 2014, 23:17
