Hey guys. You might remember me posting a thread or two here and there about using my El Gato Capture HD to record things and having a heck of a time with it, as it natively stores AVC files inside .ts containers which have proven to be a real pain to work with. Right now I'm trying to record some live sports events for archival purposes. The El Gato capture software (which is the only software that seems to read the 1080i input off my WOW! cable box correctly) stores the video as a single video stream along with multiple audio streams in a .ts file. I want to stream copy the files to .mkv using the video stream and the only relevant audio stream. The El Gato software does convert the captures to MP4, but it takes SO LONG for that transcode to happen, and I'd rather not transcode them at all if possible.
I've been trying to get better with ffmpeg lately. The command I'm using to try to make this happen is ffmpeg -i INPUT.ts -c:v copy -map 0:2 OUTPUT.mkv
This results in a file with audio only.
I've attached a MediaInfo dump of the input file in question, if that helps.Code:C:\Users\Cursed Lemon\Videos\EGC_Library\My Great Game - My Great Capture - 2019 -10-06 01-08-31>ffmpeg -i Recording_2019-10-06_01-08-31_0002.ts -c:v copy -map 0:2 test.mkv > test.txt ffmpeg version N-95216-ge6625ca41f Copyright (c) 2000-2019 the FFmpeg developers built with gcc 9.2.1 (GCC) 20190918 configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libdav1d --e nable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus - -enable-libshine --enable-libsnappy --enable-libsoxr --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --ena ble-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvorbis --enabl e-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-libxvid --enable-libaom --enable-libmfx --enable-ffnvcodec --enable-cuvid --enable-d3d1 1va --enable-nvenc --enable-nvdec --enable-dxva2 --enable-avisynth --enable-libopenmpt --enable-amf libavutil 56. 35.100 / 56. 35.100 libavcodec 58. 59.101 / 58. 59.101 libavformat 58. 33.100 / 58. 33.100 libavdevice 58. 9.100 / 58. 9.100 libavfilter 7. 61.100 / 7. 61.100 libswscale 5. 6.100 / 5. 6.100 libswresample 3. 6.100 / 3. 6.100 libpostproc 55. 6.100 / 55. 6.100 [mpegts @ 000000000051fe80] DTS 6834658 < 6839163 out of order [mpegts @ 000000000051fe80] Stream #1: not enough frames to estimate rate; consider increasing probesize [mpegts @ 000000000051fe80] start time for stream 1 is not set in estimate_timings_from_pts [mpegts @ 000000000051fe80] stream 1 : no TS found at start of file, duration not set [mpegts @ 000000000051fe80] Could not find codec parameters for stream 1 (Video: mpeg2video ([2][0][0][0] / 0x0002), none(tv)): unspecified size Consider increasing the value for the 'analyzeduration' and 'probesize' options Input #0, mpegts, from 'Recording_2019-10-06_01-08-31_0002.ts': Duration: 00:00:18.23, start: 75.974011, bitrate: 34078 kb/s Program 2 Stream #0:0[0x64]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709, top first), 1920x1080 [SAR 1:1 DAR 16:9], 29.97 fps, 59.94 tbr, 90k tbn, 59.94 tbc Stream #0:1[0x66]: Video: mpeg2video ([2][0][0][0] / 0x0002), none(tv), 90k tbr, 90k tbn, 90k tbc Stream #0:2[0x67](eng): Audio: aac (LC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 234 kb/s Stream #0:3[0x69](eng): Audio: aac (LC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 224 kb/s Stream #0:4[0x3ec](eng): Audio: aac (LC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 217 kb/s Stream #0:5[0x3f0](eng): Audio: aac (LC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 224 kb/s Stream #0:6[0x3f7](eng): Audio: aac (LC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 217 kb/s Stream #0:7[0x65](eng): Audio: aac (LC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 234 kb/s Stream #0:8[0x3f3](eng): Audio: aac (LC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 217 kb/s Stream #0:9[0x3eb](eng): Audio: aac (LC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 217 kb/s Stream #0:10[0x3f5](eng): Audio: aac (LC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 217 kb/s Stream #0:11[0x3ed](eng): Audio: aac (LC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 217 kb/s Stream #0:12[0x3f1](eng): Audio: aac (LC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 217 kb/s Stream #0:13[0x4e7](eng): Audio: aac (LC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 217 kb/s File 'test.mkv' already exists. Overwrite? [y/N] y Stream mapping: Stream #0:2 -> #0:0 (aac (native) -> vorbis (libvorbis)) Press [q] to stop, [?] for help Output #0, matroska, to 'test.mkv': Metadata: encoder : Lavf58.33.100 Stream #0:0(eng): Audio: vorbis (libvorbis) (oV[0][0] / 0x566F), 48000 Hz, stereo, fltp Metadata: encoder : Lavc58.59.101 libvorbis size= 220kB time=00:00:18.21 bitrate= 99.0kbits/s speed=9.74x video:0kB audio:208kB subtitle:0kB other streams:0kB global headers:4kB muxing overhead: 5.607529% C:\Users\Cursed Lemon\Videos\EGC_Library\My Great Game - My Great Capture - 2019-10-06 01-08-31>
Do I need to do something special to these TS files before I can just remux them into matroska files?
I think I just solved my problem, mostly. So I just used TSDoctor to demux the .ts file, which gave me a raw .264 file and an .aac file.
When I try to mux these files using FFMpeg, I am successful when muxing to MP4. However, when I try to mux to MKV, I get the following output:
Code:C:\Users\Cursed Lemon\Desktop>ffmpeg -i Recording_2019-10-06_15-21-56_0011_PID_0064_.264 -i Recording_2019-10-06_15-21-56_0011_PID_0065_.aac -c copy t est.mkv ffmpeg version N-95216-ge6625ca41f Copyright (c) 2000-2019 the FFmpeg developers built with gcc 9.2.1 (GCC) 20190918 configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libdav1d --e nable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus - -enable-libshine --enable-libsnappy --enable-libsoxr --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --ena ble-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvorbis --enabl e-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-libxvid --enable-libaom --enable-libmfx --enable-ffnvcodec --enable-cuvid --enable-d3d1 1va --enable-nvenc --enable-nvdec --enable-dxva2 --enable-avisynth --enable-libopenmpt --enable-amf libavutil 56. 35.100 / 56. 35.100 libavcodec 58. 59.101 / 58. 59.101 libavformat 58. 33.100 / 58. 33.100 libavdevice 58. 9.100 / 58. 9.100 libavfilter 7. 61.100 / 7. 61.100 libswscale 5. 6.100 / 5. 6.100 libswresample 3. 6.100 / 3. 6.100 libpostproc 55. 6.100 / 55. 6.100 [h264 @ 00000000005a02c0] Stream #0: not enough frames to estimate rate; consider increasing probesize Input #0, h264, from 'Recording_2019-10-06_15-21-56_0011_PID_0064_.264': Duration: N/A, bitrate: N/A Stream #0:0: Video: h264 (High), yuv420p(tv, bt709, top first), 1920x1080 [SAR 1:1 DAR 16:9], 29.97 fps, 29.97 tbr, 1200k tbn, 59.94 tbc [aac @ 0000000002a700c0] Estimating duration from bitrate, this may be inaccurate Input #1, aac, from 'Recording_2019-10-06_15-21-56_0011_PID_0065_.aac': Duration: 00:00:23.20, bitrate: 197 kb/s Stream #1:0: Audio: aac (LC), 48000 Hz, stereo, fltp, 198 kb/s File 'test.mkv' already exists. Overwrite? [y/N] y Output #0, matroska, to 'test.mkv': Metadata: encoder : Lavf58.33.100 Stream #0:0: Video: h264 (High) (H264 / 0x34363248), yuv420p(tv, bt709, top first), 1920x1080 [SAR 1:1 DAR 16:9], q=2-31, 29.97 fps, 29.97 tbr, 1k tbn, 1200k tbc Stream #0:1: Audio: aac (LC) ([255][0][0][0] / 0x00FF), 48000 Hz, stereo, fltp, 198 kb/s Stream mapping: Stream #0:0 -> #0:0 (copy) Stream #1:0 -> #0:1 (copy) Press [q] to stop, [?] for help [matroska @ 0000000003191680] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly [matroska @ 0000000003191680] Can't write packet with unknown timestamp av_interleaved_write_frame(): Invalid argument frame= 1 fps=0.0 q=-1.0 Lsize= 2kB time=00:00:00.00 bitrate=N/A speed=N/A video:89kB audio:1kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown Conversion failed!
You're telling it to remux only stream #2. "-c:v copy" is telling it to copy the video (rather than reencoded it) IF the video is included. But -map 2:0 is telling it to only include stream 2 (one of the audio streams) -- and it will be reencoded since you aren't specifying copy for the audio. The video is probably stream #0:
Code:ffmpeg -i INPUT.ts -codec copy -map 0:0 -map 0:2 OUTPUT.mkv
This works to include the video. However, the video for some reason is ending up as a sub-30 FPS copy, and I receive a string of the following errors all throughout the copy process:
Code:[matroska @ 000000000316c4c0] Invalid DTS: 64014 PTS: 63964 in output stream 0:0, replacing by guess
Code:[mp4 @ 000000000307c4c0] Non-monotonous DTS in output stream 0:0; previous: 15280767, current: 15280766; changing to 15280768. This may result in inco rrect timestamps in the output file.
If you have demuxed in TSDoctor then just pop the files into MKVToolNix. Doesn't re-encode same quality out same size. Takes minutes. You can actually wrap the TS file in a MKV container as well without demuxing. one step! However TSDoctor does cleanup any transmission errors so it's probably the best way to do it.
FFMPEG Batch Script wanted for H265 Remux
By VideoFanatic in forum Video ConversionReplies: 5Last Post: 21st Jan 2018, 10:38 -
Help losslessly editing single-frame 720x576 16:9 .m2v files for remux
By MK Inst in forum Newbie / General discussionsReplies: 30Last Post: 13th May 2017, 14:37 -
remux all files to mkv
By WakaFlakaFlakes in forum Video ConversionReplies: 17Last Post: 4th May 2017, 09:58 -
How do I remux selected audio tracks and subtitles using ffmpeg?
By mrjayviper in forum Newbie / General discussionsReplies: 1Last Post: 30th Jun 2016, 23:30 -
Remux .mov into .mkv (with ffmpeg - or something else)
By HoraceMcMahon in forum Video ConversionReplies: 5Last Post: 29th Feb 2016, 06:19
