I am a new user with limited technical knowledge so please bear with me,
I created an AVI file on Studio 22 and copied it to a USB Stick.
The file plays OK on the PC that was used to create it but not on my laptop.
It is also not compatible with my Samsung Smart TV.
Any advice would be appreciated
Please post a MediaInfo report on the file using Text mode, just copy and paste into the post. Next the model of the Samsung TV what formats does it support? This will be in the manual. There are some formats TV's smart or otherwise simply don't support. On your laptop it may lack a required codec.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
It's PAL DV AVI and that almost certainly will not play on most smart TVs. I just checked the manual for my 2010 Samsung, and it does NOT list DV AVI as a compatible format. Since DV is a 1990s format, it is very unlikely Samsung would have added it, so I'm 99.9% certain that is the problem with your Samsung.
Get the manual for the TV and look up what formats it will play. Then, re-render from Studio to one of those compatible formats.
You didn't say what laptop you have. If it is a MAC, they generally will not play AVI files, but will happily play the exact same video format (DV in this case) if it is put into an MOV container instead of an AVI container. -
Hardly anything outside a computer will play DV AVI. Your best bet is probably to save it as h.264 and aac in MP4.
.avi only plays audio... no video in Movie Maker 6.0 / Win Media Player
By graymouse in forum Newbie / General discussionsReplies: 8Last Post: 14th May 2017, 04:21 -
Need Help Converting an AVI file from a CCTV system - Plays in WinMedia
By webby88 in forum Video ConversionReplies: 1Last Post: 10th Apr 2016, 13:08 -
what about USB file display for non-Philips devices?
By PaulGor in forum DVD & Blu-ray PlayersReplies: 1Last Post: 16th Jan 2016, 18:49 -
Video exported with pinnacle16 :image plays then freezes audio plays fine
By RonWolpa in forum Newbie / General discussionsReplies: 0Last Post: 23rd Oct 2015, 17:00 -
10GB avi file only plays last second
By Bryo in forum Newbie / General discussionsReplies: 1Last Post: 21st Jun 2015, 21:12
