Hi, I usually have three MOV files (registered with my Nikon D3500) that I want to join together in one mp4 file. I am able to doing so with Adobe Premiere Pro, and it takes about 15 minutes. Considering that my trial period is about to finish, I decided to go with Avidemux. How can I figure out the encoding settings that Premiere use in order to obtain the exact result with Avidemux (same file size: ~3.6GB for a 50min video; same time taken to encode)?
In premiere I simply take my three MOV file, I drop it on the time line, and I export the video using the default "Match Source - High bitrate" option.
I also downloaded MediaInfo to obtain all possible information about the output file produced by Premiere:
Can you tells me what options I need to tweek in order to obtain this?General
Complete name : C:\Users\Cristian\Desktop\premiere-output.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42/mp41)
File size : 3.61 GiB
Duration : 49 min 38 s
Overall bit rate : 10.4 Mb/s
Encoded date : UTC 2019-09-30 13:28:58
Tagged date : UTC 2019-09-30 13:31:31
TIM : 00:00:00:00
TSC : 30000
TSZ : 1001
Video
Format : AVC
Format profile : Main@L4.1
Format settings : CABAC / 2 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 2 frames
Format settings, GOP : M=3, N=29
Codec ID : avc1
Source duration : 49 min 38 s
Bit rate mode : Variable
Bit rate : 10.1 Mb/s
Maximum bit rate : 12.0 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 (30000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.162
Stream size : 3.50 GiB (97%)
Source stream size : 3.50 GiB (97%)
Language : English
Tagged date : UTC 2019-09-30 13:28:58
Codec configuration box : avcC
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Bit rate : 317 kb/s
Maximum bit rate : 330 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 113 MiB (3%)
Source stream size : 113 MiB (3%)
Language : English
I use Avidemux 2.7.5
Thanks.
Results 1 to 1 of 1
Extract video file from youtubedl ?
By PowerFalcon in forum Video Streaming DownloadingReplies: 12Last Post: 17th Oct 2018, 19:46 -
Avidemux Output settings
By abesty123 in forum EditingReplies: 0Last Post: 30th May 2017, 23:16 -
Can I use Avidemux to add a clip to the middle of an existing video?
By J Tinsby in forum EditingReplies: 5Last Post: 18th Sep 2016, 00:46 -
Help: Trying to replicate .mp4 encode settings from existing files (Mac)
By U2Joshua in forum Newbie / General discussionsReplies: 2Last Post: 29th Mar 2016, 08:42 -
Avidemux is mirroring my video file
By jrtly in forum Newbie / General discussionsReplies: 8Last Post: 29th May 2015, 18:48
