Forgive me if this has been asked before, but I'm trying to add subtitles (srt) to a movie (iso). The iso already has a "subtitles" option in the main menu, but the subtitles themselves are not added, so the option does nothing. How would I go about adding subtitles so that I can turn them on or off with the "subtitles" option in the main menu? Is the process different for Bluray vs. DVD? I also have the subtitles in .sup format.
You say "movie (iso)" but you neglect to say what kind of "movie (iso)". DVD or Blu-Ray? And what kind of SUP file? Blu-Ray or DVD?
And yes, the process is different depending on whether DVD or Blu-Ray. The first thing to do is to take it out of ISO. You should probably demux after that. -
If you are willing to do without menus, you could create an MKV from the Blu-ray and add new subtitles (in Blu-ray format).
However, at this point, there is no method for simply adding or replacing subtitles in an existing Blu-ray movie ISO. There used to be software that claimed to be able to replace or add subtitles to an existing Blu-ray movie but that software (priced at about $400) is no longer available and I cannot confirm that it actually worked as advertised.Ignore list: hello_hello, tried, TechLord, Snoopy329
Adding subtitles
By Marios Georgiou in forum SubtitleReplies: 1Last Post: 29th Apr 2017, 15:49 -
adding embedded subtitles ??
By kenny1999 in forum Newbie / General discussionsReplies: 4Last Post: 14th Nov 2016, 03:42 -
adding subtitles to 3D .iso
By THX-UltraII in forum SubtitleReplies: 4Last Post: 9th Jun 2015, 03:46 -
Adding only limited subtitles
By DudleyAz in forum SubtitleReplies: 5Last Post: 26th Feb 2015, 02:11 -
TAW5 Menu Background movie - menu items
By SefR in forum Authoring (Blu-ray)Replies: 3Last Post: 31st Dec 2014, 05:49
