If you're converting 24 FPS to 30 FPS, wouldn't this mean the picture initially gets ahead of the audio, only for the audio to catch up later when duplicate fields are displayed?
Like, if you're showing two fields that correspond to a complete frame, that picture is now displayed for a shorter amount of time than it was on film, since the frame rate is higher to accommodate the extra fields.
Or is it just such a small difference that it's imperceptible to the viewer?
When you telecine film the audio stays in perfect sync. That is because you assign a playback speed to the video that plays the different number of frames (more if you are converting 24 --> 30, or fewer if you are doing IVTC to go 30 --> 24) in the exact same amount of time.
The two fields are shown over the course of ~1/30 sec.
The film frame is shown over 1/24 sec.
The video fields occupy a shorter time, but consequently, a shorter portion of the audio track is played during this time. So sync is maintained.
In Avisynth, you can confirm this using something like ChangeFPS(60) on a 24fps file and comparing the length of audio per-frame with VirtualDub's audio display or AudioGraph. -
It's a type of jitter, but one that is small enough that it is rarely/occasionally noticeable, much less objectionable. At most, going from 24p to 60i, it could theoretically (though not as much in practice) deviate 1/2 field. That is 1/120th sec or 8.333 msec.
Others, correct me if I'm wrong...
Scott -
DV File Audio Video Sync Issues - Audio Drift
By Christina in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 2nd Mar 2020, 06:58 -
Audio sync problem — video goes out of sync after a while
By maxalfreeman in forum AudioReplies: 4Last Post: 12th Sep 2019, 13:07 -
Deinterlacing inverse telecined video
By Colek in forum Video ConversionReplies: 4Last Post: 9th Aug 2016, 08:51 -
Random audio/video sync problem with webcam recorded video
By TinoArts in forum Video ConversionReplies: 2Last Post: 3rd Aug 2016, 12:57 -
VirtualDub audio out of sync, other video players all in sync
By a1s2d3f4 in forum Newbie / General discussionsReplies: 7Last Post: 11th Apr 2016, 21:36
