When trying to play UHD content on my desktop (16 core) machine using Zoom Player, about half the files I tried to play showed corrupt pictures, blank screens, and other severe artifacts, along with plenty of player crashes.
A similar software setup, but running on a HTPC (quadcore) in the living room works perfectly.
After a lot of messing around I discovered that setting "Threads for Multi-Threading" in LAV Video Decoder Properties to a value other than "Auto" makes the problem go away. 4 threads are not enough. 8 threads seem to be enough for the highest bitrate file I have (62181kbps). Setting 16 threads gives good results, as does setting 24 threads. Setting 32 threads gives the same behavior as setting "Auto". It is likely that "Auto" is the same as "however many your CPU can run" - 32 on the Threadripper.
I guess that having too many video decoder threads running is causing a problem somewhere.
A workaround is to set a lower number of threads.
Results 1 to 1 of 1
Thread: Possible bug in LAV video filter
Bitstreaming DTS-HD MA with lav filter / potplayer
By imhh1 in forum AudioReplies: 7Last Post: 3rd Oct 2020, 09:46 -
Video stuttering in MPC-HC/potplayer [LAV megafilter]
By Robert Paulson in forum Software PlayingReplies: 0Last Post: 6th May 2019, 14:11 -
LAV Video + madVR = stutter
By slit in forum Software PlayingReplies: 4Last Post: 20th Sep 2018, 09:55 -
HEVC Lav Filter
By HerrHogan in forum Software PlayingReplies: 0Last Post: 30th Nov 2017, 14:19 -
DTS to WAV through LAV Audio directshow filter
By kliffgomel in forum AudioReplies: 12Last Post: 7th Jan 2015, 08:29
