Is it possible to resize an AVI to a bigger size without losing too much video quality.
If so how can you do it?
The resize filter in virtualdub does a pretty good job but the quality of the result obviously depends vey much on how much of a resize you perform. The more you increase the size the greater the quality loss is going to be no matter how good the resize filter.
If quality is an issue never re-size up, you also re-size the artifacts and blockyness as well as the video. I will only resize down never up.
If the frame size is important and not the video size try using an editor such as Premiere or MSP and use the video over video option to put the original footage (keeping the original frame size) on to a larger frame. That way you maintain the quality of the original but have the advantage of the larger frame.
Resizing and joining two avi files and keeping file size down
By wayc00lio in forum Newbie / General discussionsReplies: 5Last Post: 16th Feb 2011, 10:18 -
Avi resizing or creating quick dvd using avidemux
By striker9 in forum Video ConversionReplies: 13Last Post: 2nd Nov 2010, 11:01 -
DVD to AVI resizing problem
By okman in forum DVD RippingReplies: 10Last Post: 2nd Jan 2010, 00:46 -
Convert 16:9 AVI to MP4 and resizing for mobile phone (?)
By wldworld in forum Video ConversionReplies: 2Last Post: 6th Jul 2008, 23:48 -
Resizing AVI and changing bitrate using Virtualdub and XviD
By mlwitchking in forum EditingReplies: 7Last Post: 27th May 2007, 14:45
