Hi,i would like to convert DivX to VCD following the guide,but i'm not sure if all tools goes with Windows XP.
and to be sure,it is really important to install both DivX codec or i could be able to convert DivX to VCD without those codec.
Thank you.
When a program converts from one video format to another, it first has to decode the original in the same way that a player application does, only it stores the decoded info in memory rather than drawing it onto the screen. This decoded info is then passed to the encoding engine to be converted into the desired format. So, to answer your question, you do need the relevant divx codec installed in order to encode into a different format.
AFAIK, all apps and codecs discussed on this site and within these forums work ok under winxp.
How to convert a Blu-ray to a standard DVD using free tools
By Baldrick in forum User guidesReplies: 5Last Post: 11th Aug 2013, 21:50 -
D-Vision 3 tools question
By elAIalCUETE in forum Authoring (DVD)Replies: 0Last Post: 11th Dec 2011, 10:44 -
Software tools to batch convert the following (details inside)
By spycam in forum AudioReplies: 0Last Post: 3rd Sep 2011, 08:29 -
How can I convert and burn .WMV files to DVD using WIN XP tools?
By Sam-SS in forum Video ConversionReplies: 4Last Post: 16th Nov 2007, 14:09 -
Convert a dvd to avi tools which are freeware
By loninappleton in forum Newbie / General discussionsReplies: 2Last Post: 7th May 2007, 13:13
