    Sep 2019
    Australia
    I'm in Australia and have a 240-v NEC NTSC Playback vcr connected to a Sony Bravia NTSC tv I brought from the U.S. Via an adapter, the tv's power is 19.5 v DC from 240-v 50-Hz line current. Playback of U.S. VHS tapes produces black and white video only. Silly me, I assumed an "NTSC" vcr could play NTSC VHS tapes to an NTSC tv. Can anyone explain why the video is only black and white?
  2. Member Cornucopia's Avatar
    Model #s...?
    Scott7
  3. Your VCR probably isn't an NTSC VCR but rather a PAL VCR. Most PAL VCRs can play NTSC tapes. But when they do so they output a signal that has NTSC timing on the luma but PAL chroma -- called PAL60. PAL TVs understand that signal and will play it properly -- with full color. An NTSC TV understands the luma but not the chroma. Hence a greyscale picture.
    Sep 2019
    Australia
    The Model is a NEC VH-604.
    Thank you, jagabo. I read about PAL 60 but didn't see an explanation why black and white only was produced.
    I reckon the vcr has the label "NTSC Playback" on the front because NEC assumes if it's 240 v, then you must be in a PAL country like Australia and are connecting to a PAL tv.
  5. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    NTSC playback in a PAL country is rarely a problem.
    PAL playback in an NTSC country is almost ALWAYS a problem.
    It has nothing to do with voltage by the way.
  6. Originally Posted by Communer View Post
    But don't you have a PAL TV you can view the tape with? That should display the picture properly. From the VH-602 manual (probably similar):
    https://www.manualslib.com/manual/1100993/Nec-Vh-602.html?page=2#manual
    NTSC PLAYBACK ON PAL CTV Allows you to play NTSC video tapes from overseas on most brands of colour television receivers capable of resolving at 60 Hz video signal.
  7. Member Cornucopia's Avatar
    My thought exactly, which is why I wanted the model #s.
    Sep 2019
    Australia
    Yes, I have a PAL tv. I can play my tapes now that I have connected the vcr to the proper tv. I first tried the NTSC Bravia because I was unaware of the chrominance signal difference. I wrongly assumed that because both devices are "NTSC" that compensatory circuitry was included that would provide the complete viewing experience. Live and learn.
    Thank you for the manual link.
