Its hard to describe this problem but here goes-
I have inserted a video produced with my Canon EOS 70D into a DVD I am producing. The video is of a distance shot over a lake where I pan across the scene.
Houses on the far shoreline dither/shake as the scene pans across.
The raw video is perfect when viewed on a large screen so the problem is not with the camera. Also. in Pinnacle Studio 'Author'; if I play the scene at full screen is it also fine. The problem therefore seems to be when I burn the DVD. PAL format.
Any suggestion as to how I can resolve this issue?
Results 1 to 11 of 11
It's always helpful to post a short sample -- especially if it's hard to describe.
It may just be a function of framerate/shutter speed. Or you may be dropping frames when you downconvert to DVD. -
I have produced a snippet of the movie from the VOB file which shows the problem.
This is known as "aliasing"
It's probably in the source . But there is a small chance that something else in your workflow caused it. You can confirm this by looking at the source closely
Many DSLR's are known for this, especially older ones. The large sensor is downsampled by skipping lines , every nth pixel, when shooting video . The reason is they were not fast enough to do a proper resize, and would frequently overheat
What can you do about it ? There are some strong temporal antialiasing filters that might be able to smooth things out , for example avisynth filters such as QTGMC in progressive mode -
I see.
That aliasing appears to be an artifact of downscaling (based on your saying it's clean out of the camera.) You may want to try outputting at full size and then trying some of the methods poisondeathray has suggested. You can also try softening up that part of the frame in Pinnacle and see if that helps on output. -
Take a closer look - I doubt it's completely clean out of the camera . I've had a few Canon DSLR's over the years.
The reason why it's more visible, is when you have duplicate frames introduced for making the DVD (29.97 fps) , there is a supposedly static frame (no motion), but a twitch in the aliasing pattern . This can also be from deinterlacing applied when watching it, or when making the sample video. If you make a progressive DVD, this other issue shouldn't be contributing
Since it's a pan of a mostly static background (only the BG is affected with the aliasing), another fix would be to replace the background. You'd do this with motion tracking; basically sticking a masked still image that "sticks" over the affected area, guided by the motion tracking data . In the past it could only be done by tools such as after effects, by many entry-mid level editors have motion tracking now. Not sure if Pinnacle Studio has . But you'd have to do fixes for each shot, and not all shots are easily fixed (not all static BG's) -
Here is the source video from the camera.
I'm not aware of QTGMC but I will look into it - thank you
What is meant by 'You can also try softening up that part of the frame in Pinnacle' ?
I have to say I have produced numerous DVDs which include short videos from my camera and have never seen this effect before. I was wondering if I had mis-set some parameter in the burn process. -
What are your project/timeline settings ? And what were the export settings - what type of "PAL" DVD are you making ? 25p ? or interlaced
Is this a mixed footage project (other cameras), or is primary footage from this camera at 1080p23.976 ?
I think it's being deinterlaced somewhere where it shouldn't be . Certain the MP4 was, but that might be from the preparation of the MP4 -
Your questions have identified the problem.
I was recording on the DVD at 50 fps when my camera recorded the video at 25!
Cannot think how I came to change this but thank you very much for helping me.
This is a very useful Forum.
Pinnacle Studio 19
By DonH in forum EditingReplies: 4Last Post: 27th Sep 2019, 09:46 -
Dithering Settings in Audacity
By Dabuss55 in forum AudioReplies: 4Last Post: 22nd Jun 2019, 06:52 -
Pinnacle Studio 21 Ultimate, No PIP?
By Shadow of neo in forum Newbie / General discussionsReplies: 0Last Post: 7th Oct 2018, 07:36 -
Problems with Pinnacle Studio
By confusedperson in forum Capturing and VCRReplies: 1Last Post: 20th May 2016, 16:29 -
EzCap with Pinnacle studio
By OzPT in forum Capturing and VCRReplies: 0Last Post: 9th Jun 2015, 04:00
