Hey,
I've been using the MMC 7.1 (latest availible on ATI website as far as i see) but the capture resolutions in there are pretty crappy and don't even reach SVCD specs.
I've seen people here talk about MMV 7.6 -- that availible for the TV-Wonder VE ?
Or can someone recommend another capture program that supports this card well (Both coax & composite input, sterteo sound) and that also captures to VCD / SVCD at high resolutions with no framedrops ?
My specs: Athlon XP 1700+, 512MB DDR, TV-Wonder VE PCI, Geforce 4 MX 440, Abit KG7 raid MB, ATA100 / 7200RPM Quantum Fireball AS Plus 40GB HDD, 16x DVD, 24x Burner.
My system isnt crap so it shouldnt get frame drops, and lots of people tell me ATI's software is crap. I gotta agree. Any recommendations to go with this card ?
MMC 7.5 is a lot better, but VirtualDub & Tmpeg seems to make for higher quality.
As for capturing directly to VCD/SVCD, forget it. Your machines fast enough to capture with MMC7.5 & convert in TMPEG without it being too time consuming and it produces far superior results. Stink's reg tool helps with higher res captures but as I only use VCD I've only done this once or twice.
On a side note did anyone get MMC 7.6 to work with the TV Wonder? -
I was able to get 7.6 to work by taking the setup.inx file from 7.5 and moved it into my install folder.
I was also able to use Stinky's reg tool to set up SVCD template. The problem I'm encountering is once I burn using Nero, the video seems a bit jerky so any comment on what I'm doing wrong would be appreciated.
Duron 900, Win XP
256 MB (not DDR)
TV Wonder PCI -
Thanks for the tip with MMC 7.6, don't know what's up with your SVCD's though, the few I've done work fine. You are running them through TMPEG's multiplexer first right?
Does your DVD player support SVCD's? if it usually plays SVCD's without a problem then try lowering the bitrate in my template.Originally Posted by Fen
If the problem still continues try switching to the X-Rez SVCD settings.
Always make small sample files (about a minute long) and burn them all to one CDR so you don't waste disks figuring out what setup works best for you.... also make sure your doing what svetz's said "run them through TMPGEnc's multiplexer first"your pal,
Stinky -
Thanks for the tips, can someone tell me where I can download MMC 7.5 / 7.6 ? All I see on ATI's site is the 7.1 for my card..
Fen or others would have to explain how to install MMC 7.6 for your card. It's on the ATI site but not listed for your card.
You will need a file from MMC 7.5 -- you can find MMC 7.5 on http://www.filemirrors.com/ or maybe someone will email you the file you need and then you can skip downloading MMC 7.5your pal,
Stinky -
I was able to get both versions from filemirrors.com.
Thanks for the info, Stinky. I'll try lowering the bitrate. I can't get some of your SVCD templates to work, but I think your SVCD template works so that's what I use. Right now I'm making an uninformed guess that my problem is processing/memory power.
Again, gotta give profs to Stinky. I wouldn't be this far without his stuff.
How to restore old VCD to high definition
By rainman7 in forum RestorationReplies: 6Last Post: 5th May 2011, 00:17 -
Help finding an AviSynth deblocking filter that works at high resolutions
By Cman21 in forum EditingReplies: 17Last Post: 9th Nov 2010, 07:30 -
Are there any Capture program that can capture in high resolutions?
By Wooooooo in forum Capturing and VCRReplies: 2Last Post: 7th Jan 2008, 16:39 -
Is there a good Capture program where you can capture in high resolutions?
By Wooooooo in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2008, 12:20 -
Monitor split for high resolutions? (KVM)
By lordsmurf in forum ComputerReplies: 9Last Post: 5th Dec 2007, 16:30
