Is there a tutorial or software that can do it?
Tons of past posts on the subject.
1. Decode to 2x views & resize to full height.
2. Do complementary color adjustment of the views.
3. Overlay the 2 views into 1.
4. Re-encode.
Probably best done in AVISynth. In fact, there was a plugin/script called "Pantarheon" (iirc) that did all the heavy lifting for you.
Add/Remove black borders in the top/bottom of a video without reencoding.
By November in forum EditingReplies: 10Last Post: 11th May 2019, 08:48 -
Side by side SBS or top bottom 3d video and modern codecs efficiency
By Bernix in forum Newbie / General discussionsReplies: 11Last Post: 20th Oct 2018, 06:51 -
Changing the resolution of MP4 video by adding black band to top and bottom
By Crea in forum Video ConversionReplies: 10Last Post: 15th Aug 2015, 18:18 -
Convert 3D Side by Side to Top and Bottom?
By spiritofcat in forum Video ConversionReplies: 16Last Post: 23rd Mar 2015, 07:40 -
How to convert a Top-Bottom mkv-file to SBS
By ErwinForum in forum Video ConversionReplies: 0Last Post: 17th Feb 2015, 07:18
