    Sep 2019
    England
    I have been using various versions of this software but on coming back to my current version, t I find that on editing, the colours of the pictures in the review panel when Timeline is selected are very weak and not representative as seen when Source is selected.
    Can anyone suggest where my problem lies?
    Thank you
    Apr 2003
    Have you asked on the Pinnacle forum? Might be a good idea to post there too.
    http://forums.pinnaclesys.com/forums/242/ShowForum.aspx
    Is there a reason you're using this software?
    It's always been infamous, and pretty much any NLE is better.
    Apr 2003
    ^^And not many here use it; that's why I pointed to the Pinnacle forum.
    Sep 2019
    England
    Thanks - but I started the DVD afresh and the problem has disappeared.
