Hello, i have Some movies in x265 and it won't support on my Device,
Can i Decompress that x265 into x264 without Loosing Video Quality..
Yes, using x264 lossless. But the resulting file will be larger by by a factor of ~50 and your device probably won't be able to play it (hardly anything outside a computer plays x264 lossless).
To make a file that your device will play you will have to lose a little quality. Maybe so little you won't notice. Try a program like Handbrake and encode with a Rate Factor of 18. Use a lower RF if you want higher quality (larger file), more if you want a smaller file size (lower quality). -
follow jagabos advice.. the important thing is being able to play your file on your device..
Isn't there any Way to Decompress, Without Re-encoding
My Pc is very Low Configuration (Intel i5)
And it will take Lots of time for Re-encoding
I don't Have any problem if size will be double but i want some quicks way to Change Convet into x264 -
Sure you can decompress without reencoding (that's what a player does). But the file size will increase 10x to 50x, not 2x.
What i5 CPU do you have? Many include h.265 GPU decoding for playback (if you use a player that supports it). And most have h.264 GPU encoding for fairly quick encoding (Handbrake supports Intel Quick Sync h.264 GPU encoding).Last edited by jagabo; 22nd Sep 2019 at 11:54.
Converting x265 to x264 requires reencoding... And that takes time because you are expanding and compressing it in the process.No way out of that..
Why are you have H254 movies if you can't play them in the first place...
Are these movies aren't of legal in the first place? if they aren't we are not supposed to help you..Last edited by teodz1984; 22nd Sep 2019 at 21:05.
H265(HEVC) to H264 without loss of audio quality?
By pauljuhn in forum Video ConversionReplies: 5Last Post: 26th Mar 2017, 20:49 -
How do I Save my project in H265/HEVC ?
By Sloppy_turtle in forum Video ConversionReplies: 2Last Post: 3rd Feb 2017, 09:14 -
Video Quality Testing of HEVC Compresssion. H265 vs H264: 50% bitrate saved
By Baldrick in forum Latest Video NewsReplies: 25Last Post: 2nd Jan 2017, 05:38 -
One computer streams HEVC H265 the other doesn't. Why?
By RaiderSteveO in forum Video Streaming DownloadingReplies: 4Last Post: 20th Jan 2016, 18:54 -
H265/HEVC samples
By deadrats in forum Latest Video NewsReplies: 51Last Post: 23rd Mar 2015, 02:15
