Is there any way to remove the filter that only adds video files from a directory?
I have a lot of multimedia files I want to go through at a time, within the same playlist.
VLC could do this but for some reason can't playback .gifs
PotPlayer can play everything, but I have to tell it to select ALL file types, not just the supported ones, and then add them "manually". I can't just add the directory, or drag & drop.
It's cumbersome and unnecessary given that it can very well handle pictures too.
So, is there any way of forcing it to stop filtering items?
	Solved it!
 You need to go into Preferences -> Association -> Set File Extensions in File Open Dialog (at the bottom)
 And there you can set all the extensions you want!
  PotPlayer playlist confusionBy TBacker in forum Software PlayingReplies: 0Last Post: 16th Jul 2018, 00:04
  PotPlayer: Advancing the Playlist issueBy lemings in forum Software PlayingReplies: 1Last Post: 22nd Jun 2017, 14:40
  POTPLAYER cannot ATTACH PLAYLIST TO MAIN for AUDIO filesBy JJonaJameson in forum AudioReplies: 6Last Post: 19th Feb 2017, 21:52
  Having an Add To Potplayer Playlist option come up when right-clicking?By stevaside in forum AudioReplies: 6Last Post: 23rd Jan 2016, 00:04
  potplayer add the playlist shortcut ?By albatros44 in forum Software PlayingReplies: 0Last Post: 11th Aug 2015, 14:13
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
