I'm a newbie and not sure where this topic should go. I searched the forum for awhile, but couldn't find anything that addresses my situation.
I downloaded an mp4 video and its srt. When I played these files, the text was about 35% right, and all out of sync. (I looked for other srt's for this video, but they're all the same.) So, I decided to use Subtitle Edit to fix the problems, by editing out the wrong text, inserting the right text and syncing these lines to the video. This, in itself, has taken quite awhile, but, as I got about 4 min. into the srt, the text was pretty right on, but, there was now a gap of about 16 sec between the video (lips) and the text in the srt. I manually adjusted all of the lines by drastically changing the "Start time" (and "Duration"), but this adds a lot of processing time to the task. (I don't mind the little tweeks, but this...)
Is there a way to get rid of this 16 sec gap and have the rest of the srt's text as close to the sync time as possible? (To reduce all the remaining lines' Start Time, by 16 sec.)
Hopeful...
Select the first line after the gap. "Synchronization"->"Adjust all times"->"Selected line(s) and forward". Enter 16 seconds and click "Show earlier".
Wow...yes!!! Thank you! I'm not totally familiar with app, yet, and this is great...I tried it and it worked beautifully!
Great job! It was probably a simple thing for you but I appreciate your time and response. It's another "Brick in the wall" for me.
Thanks again. -
Moved the thread to the subtitle forum where other's can get solutions to similar issues.
Split long text into .srt lines of max 50 characters
By Miomaus in forum SubtitleReplies: 0Last Post: 17th Jun 2019, 15:08 -
Audio gap errors while demuxing with eac3to.
By lgblublu in forum EditingReplies: 0Last Post: 12th Dec 2016, 01:33 -
FFMPEG: how to fill the audio "gap" with silence?
By marcorocchini in forum Newbie / General discussionsReplies: 9Last Post: 17th Mar 2016, 15:30 -
When setting "Input FPS" in an .srt FR changer (.srt FR question)
By OpR8R in forum SubtitleReplies: 0Last Post: 27th Jun 2015, 22:24 -
Use the timing from a good srt in a bad srt that is not synched
By shernoam in forum SubtitleReplies: 4Last Post: 4th Nov 2014, 06:44
