Hey, been some years I've posted here :0 Anway, as per the title, anyone knows if there is any physical difference between NTSC and PAL blank tapes ?
i.e. Could one record NTSC on a PAL (S)VHS tape or PAL on an NTSC tape ?
Cheers and nice to see some of you are still here
Jose
Got my own answer.
They're exactly the same. The only difference is that if you record in a machine with a system the tape was not intended for the recording time will be different due to the different speeds.
Cheers -
Yep a NTSC T-120 tape(the standard most common tape) will be the same as a E-180 tape, used in PAL land. Reason being the standard SP recording time in NTSC land is 120min but in PAL land their standard speed gives them 180 minutes.
I believe our T-160(commonly called 8hr) NTSC tape might be a E-240??
The longest tape I ever saw in NTSC land was a T-200 but it was very thin. All tapes fit and record in a VHS machines but of course a PAL recording won't really play well in a NTSC only machine and visa versa.
Blank VHS tapes today : What's the general consensus on the best to use?
By ProperRogue in forum MediaReplies: 51Last Post: 22nd Jun 2024, 10:18 -
How can I watch my PAL VHS Tapes on NTSC TV?
By artemis in forum Video ConversionReplies: 2Last Post: 30th Jul 2018, 04:50 -
Is it true all PAL VCRs can play NTSC, PAL, SECAM tapes?
By digicube in forum Capturing and VCRReplies: 26Last Post: 16th Sep 2017, 11:20 -
Which legacy mini DV camcorders can play both NTSC and PAL tapes?
By digicube in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 23rd Jan 2017, 11:50 -
PAL VHS tapes to digital conversion help
By alfaromeo155 in forum Video ConversionReplies: 22Last Post: 31st Jan 2015, 21:35
