Quick question. I know that DGIndexNv is tailored for M2TS, but it also supports VOB. And for those cases in particular would you consider it better to stick to DGIndex or would DGIndexNv do the trick? I can't seem to find any information regarding IDCT algorithms when using DGSource or any post process options like deblocking/deringing that are available in Mpeg2Source.
Results 1 to 14 of 14
Red highlight>>>don't think so
Blue highlight>>>what cases are you talking about
You can always ask at
http://rationalqm.us/board/index.php -
Really? I was fairly convinced that DGIndexNv was specifically engineered to allow for indexing AVC/VC1, and that the MPG support was mostly available because it was based on DGIndex. (And if it is a fork, the original DGIndex may have evolved further on MPG processing)
I am talking here specifically about indexing VOB/MPG sources. If the above statement is true I could see how DGIndex would fare better that DGIndexNv for those. -
In your original post you named M2TS which is a container format. AVC/VC1 are video compression formats - apples and oranges. By the way, DGDecNV also decodes HEVC and MPEG2.
For those you only need DGIndex/DGDecode. I would however recommend DGDecNV for this as well if you have a compatible NVidia card/chip. -
You'll have to ask Donald Graft on his forum.
If you want to stick with DGIndex/DGDecode, I made a build using the Intel compiler which increases decoding speed quite significantly:
https://forum.doom9.org/showthread.php?t=173259
(DGMPEGDec 1.5.8) -
I tried doing this based on something I read
There was no differences, so with this I believe the IDCT used is the IEEE-180 which is perfect.A=Mpeg2Source("01.d2v", idct=5, cpu2="oooooo")
B=DGDecode("01.dgi")
subtract(A,B) -
That's very impressive!
Meanwhile, wondering if there may be some bitterness. Let it go. Though DG forum can't be such a useless forum, else there would be no reason to be exercised about it, to the extent of making the kind of posts we have seen here.
Partaking of the peace pipe, we could have a world where everybody stays away from politics and respects people and your account comes back as a Distinguished Member in recognition of your excellent work for the community (AVSMeter, Avisynth Universal Installer, etc.) and your valuable forum postings. Let's erase the past and embrace each other. We have goodness inside us and we are all children of the divine spirit.
For the benefit of culture lovers everywhere, here is the DG forum:
Check out the CUDA subforum. Lots of exciting things going on!
And here is an entry point of yours that we all are grateful for:
https://forum.doom9.org/showthread.php?t=174797Last edited by veresov; 27th Sep 2019 at 01:48.
Why I Won't Use DGIndexNV Anymore...
By VideoFanatic in forum Video ConversionReplies: 2Last Post: 31st Mar 2018, 12:19 -
Different DAR between Mediainfo and DGIndex
By tppytel in forum Video ConversionReplies: 8Last Post: 30th Sep 2017, 12:50 -
Possible to use DGIndex on MKV files from MakeMKV?
By SaurusX in forum Video ConversionReplies: 4Last Post: 23rd Aug 2017, 19:30 -
DGIndex or MKVs for DVDs?
By TheLastOfThem in forum Video ConversionReplies: 10Last Post: 25th Jul 2016, 22:21 -
DGIndex problem
By Mark22 in forum Video ConversionReplies: 21Last Post: 22nd Jan 2015, 06:38
