I get error on Startup of Win10 system "Exception at UpdateWriteLog0 hexadecimal value 0x00, is an invalid character Line 1 Position 1" and option to click OK. I click OK and PC continues to boot normally. Searches I did found results for this error when running some program, but I found no results for the error at startup. Does anyone know the cause or a fix for this problem?
Results 1 to 14 of 14
The program that gives you the error is the one starting on boot up,look in taskbar/startup and the startup folder to see the program and see which one gives you the error when you try and start it up.
you can turn off startup programs until you find the bad one. run the msconfig program/start tab/ and turn off any you think might have been added recently and/or causing the issue.
Msconfig doesn't have the startup tab in windows 10,it's in bottom taskbar/task manager/startup.
good god johns0. you run win10??? i'm all in linux when win7 support dies.
I've customized windows 10 so it's more like winxp/win7,I disabled the ribbon display,disabled auto arrange,installed open-shell to get back the start button and regular menu layout.
and it lets you install any software from anywhere and run any program you want?
nice to know. i was lead to believe otherwise. i'm on the dark web a bit...
If a startup program is causing the error, I assume that program is likely not starting and that it should cause no problem other than the program not running. Is this correct? Also can the program be started after Windows is loaded if it's not started on startup?
Anything in Event Viewer, either under "Application" or "System" ? (Don't know where to find it in Windows 10.)
Crystaldiskinfo error message changed
By lingyi in forum ComputerReplies: 1Last Post: 29th Sep 2019, 16:14 -
RemoveDirtMC Error message
By TeNSoR in forum Newbie / General discussionsReplies: 5Last Post: 13th Jul 2018, 09:03 -
Error When Trying to Use Fileboom Site - Error Message Appears
By devilcoelhodog in forum Newbie / General discussionsReplies: 5Last Post: 13th Feb 2017, 07:34 -
Streamclip Error Message
By GroundHogSOS in forum Video ConversionReplies: 5Last Post: 12th Feb 2016, 13:46 -
need help with ffmpeg error message
By mulliganman in forum Video Streaming DownloadingReplies: 0Last Post: 9th Feb 2016, 16:33
