Hello, I'm trying to convert mkvs ripped from my blu rays and convert them to mpeg2 so that I can burn them to dvds for my kids. The issue I'm having is that with each program I've tried, the 5.1 surround gets turned into stereo. I've watched plenty of dvds throughout the years with 5.1 surround, so I should be able to convert and keep the 5.1 audio before burning the mpeg2s to a dvd, right? All help is greatly appreciated, thanks.
It may be more helpful if you mention the programs you used, and maybe an example of what you did in such programs.
The multichannel formats that both dvd and bluray have in common are dts & ac3. Lpcm can easily be multichannel (mc) in bluray, but runs into compatibility and bitrate issues in dvd. Lossless bd formats are not part of the dvd spec. Mp2 is not part of the bd spec.
With those 2 formats you can do a simple & straightforward demux & remux (and author). Any other option will entail a decode & re-encode, which will have accompanying loss of quality, if not necessarily loss of channels.
If you have lossless files with backward compatibility, you could take the lossy core and reuse that. It won't have an additional generation of loss, but you would be using the inferior lossy version instead of the full lossless version.
Btw, ac3 is preferrable, as the spec would require a different format as primary stream with dts occupying 2nd stream if you went the dts route.
Scott -
Extract the audio (MKVExtractGUI), and confirm it's already DVD-compliant and doesn't itself have to be reencoded. Extract the video at the same time and reencode it to be DVD-compliant. Author the two together for DVD using Muxman.
Convert 7.1 TrueHD audio track to 5.1 DTS, keeping same video in MKV?
By BinaryDad in forum Video ConversionReplies: 2Last Post: 17th Feb 2019, 22:49 -
megui - using it's avscutter while keeping original audio
By pooksahib in forum Video ConversionReplies: 3Last Post: 28th May 2017, 09:02 -
Merging separate audio and video files into one (and keeping the shortest)
By StaffHerb in forum Video ConversionReplies: 2Last Post: 8th Dec 2016, 14:27 -
Keeping subtitles in DVD conversion
By RBTO in forum SubtitleReplies: 1Last Post: 18th Jul 2016, 11:15 -
Premiere and modifying transitions keeping audio question
By Stile in forum EditingReplies: 0Last Post: 23rd Jun 2016, 05:14
