As the title says i want to reduce the audio delay/offset step to 1ms instead of 25ms each time i press left or right. I tried to ask in the Kodi forums but no answer and i found out that in "C:\Users\Manuel\AppData\Roaming\Kodi\userdata\gui settings.xml" there is this "<audiodelay>-0.292742</audiodelay>" option for the current global offset and it can be changed affecting the current offset. Originally it's in "<audiodelay>-0.000000</audiodelay>" but "0.292742" is the audio delay I'm using right now. So that works
BUT
The option i'm interested in is "<escontinuousdelay default="true">25</escontinuousdelay>". I'm not entirely sure but i'm guessing that's the step option since it goes 25ms by 25ms, but everytime i try to change it to something like:
"<escontinuousdelay default="true">1</escontinuousdelay>"
or
"<escontinuousdelay default="true">01</escontinuousdelay>"
I even tried setting it to 0.001 or 0.000001 but it has no effect and always resets to 25!
Please if someone can help me i'd REALLY apreciate it.
That or just show me how to completely fix audio sync issues.
You couldn't tell an audio delay of 25ms, much less 1ms. Although I like to be able to delay the audio by +/- the 10ms increments you can set in MPC-HC, there's nothing really wrong with a minimum of +/- 25ms.
Are you claiming that, for example, you can tell +25ms might not be enough but +50 would be too much? If so, I don't believe you.
If +/- 25ms is what you have to work with, move it forward or backward until it sounds good to you. Perhaps set it to a sharp noise, such as a gun shot....or just show me how to completely fix audio sync issues. -
Keep in mind that each frame of a 25 fps video last for 40 ms. A 29.97 fps video has 33ms frames. And film is about ~42 ms per frame. So 1 ms increments aren't necessary.
I've read the same thing before but i still can tell the difference. I just want to know how to change it by 1 and that's all
Or if I'm using the wrong terms all i need is for THIS
to go 0.001 by 0.001 instead of 0.025 by 0.025
Please I'm desperateLast edited by Runakanta; 17th Sep 2019 at 18:31.
Maybe it's the <audiodelayrange> tag in the advancedsettings.xml file. If the default is 10 seconds and that results in 25 ms increments, the implication is that there are 400 increments (10000/25). So to reduce the increments to 1 ms you would need to set the range to 0.4 s.
https://kodi.wiki/view/Advancedsettings.xml -
This is my current advancedsettings file and the option isn't there do i add it?
I found an even better solution
how to merge multiple audio with time offset to one audio file ?
By yanshof in forum ProgrammingReplies: 6Last Post: 4th Oct 2018, 12:35 -
From VCR to DVD - step by step help please
By Solitary in forum Newbie / General discussionsReplies: 7Last Post: 28th Jul 2017, 08:16 -
How to embed subtitles into mkv STEP BY STEP using MKVMERGE and MKVEXTRACT
By lelouch283 in forum SubtitleReplies: 30Last Post: 23rd Jun 2017, 14:04 -
how to go backward step by step from dvd with potplayer?
By computerke in forum Software PlayingReplies: 7Last Post: 9th Apr 2017, 15:38 -
After effects frame offset is different from offset in Premiere
By cheyrn in forum EditingReplies: 2Last Post: 15th Nov 2014, 22:23
