Anyone know how to combine multiple vtt's to one single correct .srt ?
There's this service that has cut their subtitles into about 20 single .vtt's. Is there an easier way to glue them together as one single correct .srt based on timing?
I tried subtitle tools online but they don't support more then 2 files joining together.
a workaround i found to change all to .txt files and then use a merger. Still hoping for a faster way.
There's a join subtitles option in the tools section (very bottom) of Subtitle Edit.
I've never tried it, so can't vouch for it personally.
It also says the files must already have the correct time codes.
It might be what you're after.
what is the easy way to convert vtt to srt?
By sommers in forum SubtitleReplies: 3Last Post: 28th Jul 2020, 23:15 -
Swapping subtitles on multiple IFOs on a single dvd?
By nobodyhome in forum Authoring (DVD)Replies: 1Last Post: 5th Jul 2017, 16:25 -
Command-line method for correcting overlapping display times? vtt to srt.
By nobodyhome in forum SubtitleReplies: 2Last Post: 15th Mar 2017, 17:36 -
How to Create 1 Single IDX file from Several Independent SRT Files?
By devilcoelhodog in forum SubtitleReplies: 2Last Post: 29th Jun 2016, 17:42 -
Multiple VCDs to single DVD
By j0gz in forum Authoring (DVD)Replies: 4Last Post: 22nd Feb 2015, 16:34
