Hello,
im trying to use dvdx to backup a concert dvd with lots of fast lights and such, so 1-pass doesnt really do it. (lots of pixilation on the moving lights) but dvdx's settings arent very clear cut, any idea how 2-pass works? Dyson Cyclone V10 Review the best quality i had was using 1-pass CBR and for the 2nd pass "1-pass quality" at 100% (made the file size enormous though). just looking for the best 2-pass settings for dvdx,
thanks
iosman
I've always used one pass and got good results. But I found this for you from their site.
2 pass will not improve quality enough to be worthwhile if you use the Automatic encode option except for projects long enough that the DVD cannot be kept from being filled. So you might get some improvement with 2 pass for those longer than about 170 or 180 minutes on a DVD5 disc. But any improvement is reduced to nearly zero for projects as long as 5 hours.
If you have to use MPEG-4 ASP, I recommend the old and good DivX 6.9.2 [IF you can find it, of course] instead of Xvid.
DivX lets you adjust the scene-detection sensitivity and the 2-pass option may reduce the filesize IF the single-pass option creates an "excessively-big" stream.
Regarding H.264: if you choose it, use an x264 build which includes the fade-compensation patch, unless you want to play around with qp-files or/and zones...
VC-1 through Expression Encoder could be an interesting option as well. It opens Avisynth scripts and the VC-1 codec deals well with frequent scene changes. But in the end you'll have to remux the result to a different container (AVI, TS, MKV, MP4) and encode the audio separately (because WMA suxxx).
P.S.: I assume /hope that you DON'T INTEND to store your 'backup' on a 700 MB CD-R, of course.Last edited by El Heggunte; 29th Sep 2019 at 17:42. Reason: disambiguation
"Programmers are human-shaped machines that transform alcohol into bugs."
Settings Panasonic DMR-ES10 for pass through
By GovertdeKat in forum Capturing and VCRReplies: 4Last Post: 17th Oct 2018, 12:58 -
Virtualdubmod XVID "multiple" 2 pass compression doubt
By yomismo1982 in forum Video ConversionReplies: 2Last Post: 16th Oct 2018, 15:00 -
H264 settings: What does 2 pass encoding do?
By Anonymous754 in forum Newbie / General discussionsReplies: 13Last Post: 7th Feb 2017, 16:27 -
best xvid settings for high quality
By dirtyharry61 in forum Video ConversionReplies: 20Last Post: 21st Mar 2016, 09:49 -
Help - Creating a QWinFF XviD 2-Pass FFmpeg profile?
By thermalzombie in forum Video ConversionReplies: 2Last Post: 21st Feb 2016, 05:48
