Hi community,
My Elgato Game Capture on my mac was working fine and then I installed the latest update and now instead of showing the externally connected GoPro routed through an Elgato Game Capture HD60 S it shows this infinity desktop screen from my New MacBook Pro:
[Attachment 50135 - Click to enlarge]
I have tried the following and nothing has worked so far:
- turned computer on and off again,
- re-installed Game Capture software
- Reconnected the HD60 S
The settings have also been restored to default and no changes. Does anyone know how to fix the problem?
Check your security/privacy preferences. Iirc, the newest last 2? updates greatly increased the bar on what's automatically "allowed", so you now have to explicitly whitelist the cameras, etc.
Then, you will have a few more input options so you will need to choose your input. Not sure whether that is system-level prefs or program-level.
Elgato Game Capture HD Issues
By APStephens in forum Capturing and VCRReplies: 1Last Post: 11th May 2016, 04:21 -
How can i capture elgato game capture stream to mp4 file with graphedit ?
By Chocolade in forum Capturing and VCRReplies: 1Last Post: 17th Apr 2016, 03:23 -
Elgato Game Capture HD60 Problem
By yaston in forum Capturing and VCRReplies: 1Last Post: 12th Nov 2015, 14:57 -
Question about Elgato Game Capture HD (Not 60)
By zach890 in forum Capturing and VCRReplies: 2Last Post: 24th Jul 2015, 20:05 -
Elgato Game Capture HD (not the 60 model)
By Cesar Schrega in forum Capturing and VCRReplies: 5Last Post: 23rd Dec 2014, 21:52
