[I’m in NTSC-land]
I have a few projects that are miniDV and Super 8. I’ve been deinterlacing and upscaling miniDV to 720p 59.94fps via QTGMC (thanks to jagabo). Some of the S8 was shot at 18, some at 24fps. I’m thinking about rescanning the Super 8 at either 2 or 4K, but then was wondering how the two (or three) different frame rates will work together? At least they all will be Progressive.
Do I drop the S8 23.94fps in the 59.94 timeline, or vice-versa? Will 18fps work in a 59.94 timeline? I’ve read little bit about some sort of TimeWarp trick?
You can either interpolate to 59.94fps or you can duplicate frames to bring them up to 59.94fps, up to you. Duplication will certainly be easier and will be artifact free:
ChangeFPS(59.94) -
No, it involves creating 'in-between' frames using the existing frames on both sides.
There's no pulldown except for MPEG-2. Is that your desired output? Not DVD, of course, as 59.94fps isn't allowed for DVD.
Burning 1080p & 720p H264 To Blu Ray Using MultiAVCHD
By citycentrefox in forum Newbie / General discussionsReplies: 0Last Post: 5th Jul 2019, 20:49 -
Project & import settings adobe premiere elements
By Artsymom in forum Newbie / General discussionsReplies: 0Last Post: 10th Feb 2018, 21:51 -
Ripbot : Convert DVD to 59.94fps & Audio sync
By pstnn in forum Video ConversionReplies: 0Last Post: 6th Nov 2017, 10:53 -
Best Quality encoding from 1080p to 720p & 720p to 720p in Xvid4PSP?
By Odie111 in forum Video ConversionReplies: 8Last Post: 9th Jan 2016, 17:42 -
What Should Be The Bitrate For 720p 1080p & 4k
By DJboutit in forum Video ConversionReplies: 2Last Post: 19th Dec 2015, 19:11
