Hi, guys.
I'm running an Athlon 1.2, Abit board.
ATI AIW 128
Directx 8.1
Latest ATI drivers
MMC 7.1
Can't capture in resolution higher than 320 x 240.
Please, help me!!
Flavio
Go to tools and download free vcr. It drops less frames then v-dub and also you can select any size you want for capture. I have used it for 6 month's now without any problem.
Thanks for trying to help, but it didn't work.
Any program actually gets the capture sizo from the capture device. And the one I'm using isn't allowing bigger than 320 x 240. -
download the latest drivers for your video card, preferrably the wdm version. Then, make sure that you have dx 8.1 installed. This will take care of your problem
In addition to the latest drivers, I have had good luck with IUVCR from www.iuvcr.com
My board is an ATI TV Wonder, which is probably using the same chipset.
This was the only capture program that worked for me. I recently tried setting the capture resolution to 720 X 480 and it all worked. Of course you do consume 1 GB of disk space every 26 seconds at that resolution.
At intermediate resolutions I was able to compress on the fly with PicVideo's MJPEG compressor. At full DVD resolution the CPU (also 1.2 GHZ) runs out of steam, hence the need for a very large hard drive.
why 320 kbps mp3 have less vol compare to 128 kbps files?
By sumeshkri in forum AudioReplies: 4Last Post: 27th Sep 2008, 08:57 -
ATI AIW 128 720x480 mpeg captures have horizontal tearing
By cybertheque in forum Capturing and VCRReplies: 16Last Post: 17th Sep 2008, 21:53 -
Populating empty ATI VIP / AMC feature header on AIW Rage 128 Pro
By cybertheque in forum Capturing and VCRReplies: 3Last Post: 14th Sep 2008, 16:36 -
Flash FLV Internet Video Larger than 320 x 240
By foochuck in forum Newbie / General discussionsReplies: 3Last Post: 14th Jun 2007, 12:49 -
I can only capture at 320*240!!
By MisterBubbles in forum Capturing and VCRReplies: 1Last Post: 13th Jun 2007, 22:36
