In the intro of this video I'm working on the text has dot crawl. I want to remove it from the frames which has text, not the whole thing. How can I accomplish this? I figure its something quite simple.
Results 1 to 27 of 27
You can do it with trims:
A=Trim(0,1000.(Filter here)
B=Trim(1001,0)
A+B
You can do it using ReplaceFramesSimple (part of RemapFrames):
A=Last.(Your filter here)
ReplaceFramesSimple(Last,A,Mappings="[0 1000]") -
A=Trim(0,1000.tcomb(mode=2).Bitfrost(interlaced=true) B=Trim(1001,0) A+B
My fault and I apologize. I left out a parenthesis after the first Trim statement. Try this:
A=Trim(0,1000).tcomb(mode=2).Bitfrost(interlaced=true)
B=Trim(1001,0)
A+B -
Y'all are fine lol no harm done works fine now. Would it be too much to ask for some help with FineDehalo as well? abcxyz doesnt do too well with this source because it affects text and makes it kind of washed out. Im not sure if FineDehalo will do that. Says that theres no fuction named "expand"
Maybe you have an old version of FineDehalo? The version I have uses mt_expand(), not expand(). expand() is part of the original masktools. mt_expand is included in masktools2.
If you want specific help you should upload a sample of your source. -
I just gotta get FineDehalo working. One of the last things this source needs to be cleaned up on. I looked at my files and FineDehalo isnt the issue. Looks to be Dehalo_Alpha. The line it points to in the error message goes to this in the FineDehalo.avsi
Code:dehaloed = DeHalo_alpha (rx=rx, ry=ry, darkstr=darkstr, brightstr=brightstr)
It's hard to find mt_expand_multi.avsi. Here's the version I have:
Code:# This program is free software. It comes without any warranty, to # the extent permitted by applicable law. You can redistribute it # and/or modify it under the terms of the Do What The **** You Want # To Public License, Version 2, as published by Sam Hocevar. See # http://sam.zoy.org/wtfpl/COPYING for more details. #============================================================================= # mt_expand_multi # mt_inpand_multi # # Calls mt_expand or mt_inpand multiple times in order to grow or shrink # the mask from the desired width and height. # # Parameters: # - sw : Growing/shrinking shape width. 0 is allowed. Default: 1 # - sh : Growing/shrinking shape height. 0 is allowed. Default: 1 # - mode : "rectangle" (default), "ellipse" or "losange". Replaces the # mt_xxpand mode. Ellipses are actually combinations of # rectangles and losanges and look more like octogons. # Losanges are truncated (not scaled) when sw and sh are not # equal. # Other parameters are the same as mt_xxpand. #============================================================================= Function mt_expand_multi (clip src, int "thY", int "thC", string "mode", \ int "offx", int "offy", int "w", int "h", int "y", int "u", int "v", \ string "chroma", int "sw", int "sh") { sw = Default (sw, 1) sh = Default (sh, 1) mode = Default (mode, "rectangle") mode_m = \ (sw > 0 && sh > 0) ? ( \ (mode == "losange" || (mode == "ellipse" && (sw % 3) != 1)) \ ? "both" : "square" \ ) \ : (sw > 0 ) ? "horizontal" \ : ( sh > 0) ? "vertical" \ : "" (mode_m != "") ? src.mt_expand ( \ thY=thY, thC=thC, mode=mode_m, \ offx=offx, offy=offy, w=w, h=h, y=y, u=u, v=v, chroma=chroma \ ).mt_expand_multi ( \ thY=thY, thC=thC, mode=mode, \ offx=offx, offy=offy, w=w, h=h, y=y, u=u, v=v, chroma=chroma, \ sw=sw-1, sh=sh-1 \ ) : src } Function mt_inpand_multi (clip src, int "thY", int "thC", string "mode", \ int "offx", int "offy", int "w", int "h", int "y", int "u", int "v", \ string "chroma", int "sw", int "sh") { sw = Default (sw, 1) sh = Default (sh, 1) mode = Default (mode, "rectangle") mode_m = \ (sw > 0 && sh > 0) ? ( \ (mode == "losange" || (mode == "ellipse" && (sw % 3) != 1)) \ ? "both" : "square" \ ) \ : (sw > 0 ) ? "horizontal" \ : ( sh > 0) ? "vertical" \ : "" (mode_m != "") ? src.mt_inpand ( \ thY=thY, thC=thC, mode=mode_m, \ offx=offx, offy=offy, w=w, h=h, y=y, u=u, v=v, chroma=chroma \ ).mt_inpand_multi ( \ thY=thY, thC=thC, mode=mode, \ offx=offx, offy=offy, w=w, h=h, y=y, u=u, v=v, chroma=chroma, \ sw=sw-1, sh=sh-1 \ ) : src }
Ah, it's included with the dither package as mt_xxpand_multi.avsi.
http://avisynth.nl/index.php/Dither_tools -
I'm having no luck with FineDehalo, I think I'm doing something wrong. Here's my sample: Sample.demuxed.m2v
Here's my script:
Code:#Deinterlacing: QTGMC(Preset="Slow") Overlay(last, Loop(2,0,0).ColorYUV(gain_y=-220, cont_u=-220, cont_v=-220), mode="subtract").ColorYUV(gain_y=40, cont_u=40, cont_v=40) srestore(23.976) #Crop & Resize: Crop(12, 4, -12, -4) LanczosResize(640, 480) #Text Dot Line Removal A=Trim(0,59) B=Trim(60,149).tcomb(mode=2).Bifrost(interlaced=true) C=Trim(150,0) A+B+C #Dehaloing FineDehalo(rx=2.0, ry=2.0, thmi=60, thma=175, thlimi=50, thlima=100, darkstr=1.0, brightstr=1.0, showmask=0, contra=0.0, excl=true)
Looking at other frames, I think you need to increase rx and ry. If you use dehalo_alpha(rx=2.5, ry=3.0) pretty much all the halos are gone (there's still a tiny bit on the curve of her shoulder). Even at those values FineDehalo leaves more of a halo around the shoulder. I suspect the mask it uses to protect other parts of the image is causing more of the halo to bleed through there. You may just have to compromise.
Hey all. Is there a way I can loop FreezeFrame to do this:
ABC -> CCC
Otherwise I have to type in every 3 frames by hand and I really don't wanna do that. I tried this:
Code:A=Trim(0,1298) B=Trim(1299,1316).Loop(2,0,0).FreezeFrame(1, 2, 3) C=Trim(1317, 0) A+B+C
For every group of three frames you want to replace the first two with a copy of the third? SelectEvery(3,2,2,2).
How do I do that, but this time with every 4 frames. The 4th being copied over the other frames. I tried this to no avail:
Code:A=Trim(0,1318) B=Trim(1318,1321).SelectEvery(4,3,3,3).FreezeFrame(1, 3, 4) C=Trim(1322, 0) A+B+C
A=Trim(0,1318) B=Trim(1318,1321).SelectEvery(4,3,3,3,3) C=Trim(1322, 0) A+B+C
In every cycle of 4 frames replace the first with the fourth, the second with the fourth, the third with the fourth, and the fourth with the fourth. Counting begins with zero so the three mentioned is frame number four in the cycle.
The first number gives the cycle and the numbers mentioned after that tell you which frames in that cycle to use. Cycle of four, four threes. In the earlier example there was a cycle of three and three numbers mentioned after that.
It's thoroughly explained in the SelectEvery page. If you don't understand an AviSynth filter, all the built-in ones have their own pages. Third party ones might have a page or perhaps a reference to the discussion about it at Doom9. -
I suggest you just read the docs for SelectEvery().
http://avisynth.nl/index.php/Select
did I apply the filter syntax "-sws_flags bicubic" correctly?
By sommers in forum Newbie / General discussionsReplies: 3Last Post: 25th Jun 2017, 21:13 -
How to apply a filter only to a certain frames in avisyth?
By zanzar in forum Newbie / General discussionsReplies: 9Last Post: 7th Apr 2017, 18:11 -
Apply filter settings to all files in XviD4PSP 7
By eday_2010 in forum Video ConversionReplies: 1Last Post: 19th Dec 2016, 21:09 -
Apply Yadif using complex filter in FFmpeg
By panzerIV in forum EditingReplies: 4Last Post: 5th Jul 2016, 04:14 -
How to apply time stretch filter to avi file in VirtualDub
By ezcapper in forum Video ConversionReplies: 0Last Post: 29th Jun 2015, 22:43
