I've added some audio and subtitle tracks to a blu-ray with tsmuxer and BDedit and whenever I skip around on the timeline, the audio and subtitle tracks return to default. When I play the m2ts it's fine and maintains the same tracks, it only happens when I load up the whole disc and go through the menu. The new audio track is about a second longer than the original video so I've adjusted the out time to compensate but I'm not entirely sure what else that could affect... I'm pretty new to BDedit so I don't know my way around the program very well, is this an issue that's popped up for anyone else? I'd appreciate the help.
Mark the new tracks as default and maybe remove the original tracks if not used...
Avisynth - Audio track longer than video track
By martanius in forum AudioReplies: 4Last Post: 18th May 2018, 03:13 -
Adding an audio track and subtitle track to a DVD?
By killerteengohan in forum Authoring (DVD)Replies: 2Last Post: 9th May 2015, 19:35 -
Video conversion causes timeline change in video players?
By jaybird in forum Video ConversionReplies: 18Last Post: 2nd Apr 2015, 19:01 -
How do I (BATCH) set a specific subtitle track, and audio track as default?
By MountainSplash00 in forum Newbie / General discussionsReplies: 3Last Post: 2nd Dec 2014, 07:53 -
change audio track format
By ashkan_vpm2 in forum Video ConversionReplies: 2Last Post: 20th Sep 2014, 12:08
