I recently reinstalled Windows, which of course meant I had to reinstall all the rest of the software. Previously I somehow figured out how to disable the playlist entirely in PotPlayer, but for the life of me I can't figure out how I did it.
Any clues?
Thanks.
I'm not sure what exactly you want but if its just NOT to display playlist until you want. Click the box in the lower right side. This turns it on/off
[Attachment 50070 - Click to enlarge] -
You can also detach it from the main window by clicking the diagonally upwards pointing arrow next to the word playlist, then clicking the X to close the playlist window. This will also remove the little right arrow from the side of the main window.
Thanks, I should be more specific: I know how to hide it, but it's still using and creating a playlist, I want to disable it creating playlists. If I click on a single video/audio/media file, I don't want it to create a playlist out of everything in that folder, I just want it to play the one thing that I clicked on and then stop after it's finished playing that one media file. Before I reinstalled Windows, I had somehow made PotPlayer act the way I'm wanting (which is the same way that Windows Media Player and VLC handle things by default, as well as the Windows apps that come with a Windows 10 install), but for the life of me I can't remember how I did it.
Preferences > General > When files opened: > "Add only selected files to playlist".
PotPlayer: disable autoplay next in playlist
By madbucky in forum Software PlayingReplies: 3Last Post: 11th Mar 2023, 23:28 -
PotPlayer: Disable Auto-Play of Next File In Playlist
By jsmusiker in forum Software PlayingReplies: 19Last Post: 24th Mar 2021, 16:56 -
PotPlayer playlist confusion
By TBacker in forum Software PlayingReplies: 0Last Post: 15th Jul 2018, 23:04 -
mpc play episode from playlist which was openned last, disable subtitles
By empleat in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jun 2018, 05:44 -
potplayer add the playlist shortcut ?
By albatros44 in forum Software PlayingReplies: 0Last Post: 11th Aug 2015, 13:13
