For some reason there's an audio delay in this video which took around 12 hours to encode.
It has been deinterlaced, but I can't see why that would be a problem. Since I have done this countless other times with interlaced sources.
I use Staxrip and I tried encoding some other videos and there the audio is in sync, but on this specific video it isn't. I have the same settings on as I normal have.
I would like to know how to stop this in the future.
Also is it possible to put a audio track on a video file, without having to wait for example 12 hours again for it encode every frame.
Many muxers have the ability to add an audio delay (use a negative delay to advance the audio). For example MkvToolnix-GUI. Open your file, highlight the audio track, set the delay, save the result. It will only take a seconds.
https://www.videohelp.com/software/MKVToolNixLast edited by jagabo; 10th Sep 2019 at 13:23.
How to precisely determine the delay (in ms) when muxing video and audio
By vangeliis in forum MacReplies: 7Last Post: 28th Mar 2019, 12:56 -
How to add delay to .aac without re-encoding it?
By midts in forum AudioReplies: 6Last Post: 5th May 2017, 13:03 -
ffmpeg audio delay - how to get the video to start before the audio ?
By Selur in forum Newbie / General discussionsReplies: 6Last Post: 13th Mar 2017, 14:30 -
how to slove the delay problem when recording audio/video in potplayer?
By Erfan in forum Software PlayingReplies: 6Last Post: 2nd Jul 2016, 13:07 -
How to Delay or fix audio in video
By Aashik Alam in forum AudioReplies: 7Last Post: 6th Mar 2016, 14:08
