Which are the latest tools I can use to extract subtitles from a ripped BD?
What formats will I have then to convert to srt?
Use MakeMKV to create a MKV file. Drop this on Subtitle Edit.
This will start OCR (From PGS to amogst others SRT). In case there are more than one subtitle you'll have to chosse the one to use.
Make sure you are using Tesseract 3.02 and have the Language/Dictionary for the subtitles installed. If not use the three dots to install them.
Do the OCR and run Tools ->Fix common erors. Save as SRT.
Extracting subtitles from m4v/mp4.
By protoX in forum SubtitleReplies: 54Last Post: 16th Dec 2020, 12:26 -
Question/Help Regarding Extracting Subtitles
By truegalbklyn in forum SubtitleReplies: 1Last Post: 15th Sep 2016, 11:40 -
extracting subtitles from a DVD
By Kracov in forum SubtitleReplies: 19Last Post: 16th Mar 2016, 17:18 -
Help extracting subtitles, tried everything
By danielrika in forum SubtitleReplies: 15Last Post: 19th Mar 2015, 07:35 -
By Speeny in forum SubtitleReplies: 1Last Post: 23rd Dec 2014, 10:39
