I have a DVD with several episodes of a television show I'm replacing the audio/putting subs on but after I've replaced the pgc and exporting from VobBlanker, it gives me a warning "Number of Cells higher in replacing title. Extending last cell" This seems to be messing with the chapters because when I playback the disc, there are chapters that have doubled up (when you press "next" they just start the chapter over) and there are a few towards the end of the video that are no longer there. The Disc also contains an option to watch the show without Intro/Outro themes and the chapters on that playlist are completely out of place, but this is less important to me.
Vobblanker lists the video's duration at 2:27:58, but the video I've demuxed from the disc is slightly longer at 2:28:07, not sure if that discrepancy is what's causing this.
Any help would be appreciated!
Okay so I tried editing the frame number and VobBlanker returned the same warning, then I decided to test without the new audio to see if that was what's causing it and VobBlanker returned the same warning, again producing a disc with some incorrect chapters. Maybe it has something to do with that no intro/outro playlist? I've read DVDs containing alternate cuts can cause chapter select issues after replacing PGCs but I'm not sure that really applies here since it's just one video file. I'm starting to think about extracting the menus and authoring a whole new disc with those instead if I can't find a solution to this. Thank you for your help by the way.
After I wrote the last reply I was thinking the same as you - that even getting the celltimes.txt straightened out might not fix the problem. I was beginning to think it might have angles (the alternate cuts you mentioned) which are often hell to work with.
That's probably what I'd do, too. This assumes you're comfortable working with a menu creation program. You can use the same menu backgrounds, if you wish. I often do similar things using DVDAuthorGUI, but there are other programs for this as well.I'm starting to think about extracting the menus and authoring a whole new disc with those instead... -
Well I've never created a menu from an existing menu before, only completely custom ones, and this one has an intro animation, animation while in the menu, and then another animation when you make a selection. I'm not sure if DVDAuthorGUI or DVDStyler can handle that but I could have just not given them enough time to figure out. I do have Adobe Encore though, I'll probably try that.
Animated menus are more difficult and if you've never worked with menus before, you might want to still them for your first attempt. Here's a guide I created for the process once upon a time:
https://forum.videohelp.com/threads/254043-Guide-for-extracting-menus-for-editing-and-...g-edited-menus
It may not apply to what you want to do. If you intend just to use the menu backgrounds and have the menu program create new buttons and new simple menu commands, then the guide might not be too useful.
Intros and outros can be kept by adding them afterwards using the function for that in PGCEdit (Title->Import first play (startup) clip/Import title's intro clip/Import title's closing clip). If you want to. I might consider them extraneous but I've done similar before.
Replacing a Portion of the First BD Chapter.... Is it Possible?
By User897 in forum Newbie / General discussionsReplies: 17Last Post: 8th Sep 2019, 12:27 -
VobBlanker, replacing menu doesn't work on W7
By Instant Martian in forum DVD RippingReplies: 10Last Post: 15th Jan 2016, 08:37 -
Can't find chapter screens in VobBlanker
By StrobeLightEpileptic in forum Authoring (DVD)Replies: 2Last Post: 3rd Jun 2015, 15:06 -
Extracting chapters/chapter information from VOB file?
By killerteengohan in forum Authoring (DVD)Replies: 8Last Post: 10th May 2015, 07:00 -
Bluray Authoring Programs Without Chapter Thumbs +Text file chapter support
By VideoFanatic in forum Authoring (Blu-ray)Replies: 10Last Post: 1st Feb 2015, 13:49
