Hi, i am interested to buy this product: https://www.tbs-technology.de/shop/DVB-T-T2-C-Quad-Tuner-PCIe-Terrestrial-or-cable-TV-Card-TBS-6205
OR this product: http://www.hauppauge.co.uk/site/products/data_quadhd.html?fbclid=IwAR2f3yxpi92eL1aKu6S...MyE2FXobhy4zqM
NOTE: I only need to watch or record DVB-T-T2 channels (freeview channels)
My PC model is: HP ProDesk 400 G4 MT x64-based PC.
Are those products compatible with my pc?
If yes, can I purchase and use two Quad-Tuners from the same brand in order to connect them together and watch or record up to EIGHT(8) TV programmes at a time? I only need to watch or record DVB-T-T2 channels (freeview channels).
If yes, how can i connect them together?
Please advise!
If the HP ProDesk 400 G4 MT is the HP ProDesk 400 G4 MicroTower form-factor then it should work for either of the TV tuner card models in your post. The HP ProDesk 400 G4 MicroTower has two expansion slots each capable of holding a PCIe x1 add-on card with a full-height bracket. See https://h20195.www2.hp.com/v2/getpdf.aspx/4AA6-9028EEAP.pdf
The Hauppage WinTV-quadHD would be a neater choice if you have only one antenna/aerial because it uses only one RF connection for 4 tuners, so you only need 2 leads from the antenna for 2 cards.
You need a coaxial splitter for antennas/aerials to provide the required number of leads to feed a signal to each connection on both tuner cards.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Below is my Motherboard details:
Motherboard
Manufacturer: HP
Model: 82A1 (U3E1)
Version: KBC Version 06.21
Chipset Vendor: Intel
Chipset Model: Skylake
Chipset Revision: 07
Southbridge Vendor: Intel
Southbridge Model: H270
Southbridge Revision: 00
BIOS
Brand: HP
Version: P03 Ver. 02.11
Date: 06/11/2017
PCI Data
Slot PCI-E
Slot Type PCI-E
Slot Usage In Use
Data lanes x16
Slot Designation Slot1 / X16PCIEXP
Characteristics 3.3V, PME, SMBus
Slot Number 0
Slot PCI-E
Slot Type PCI-E
Slot Usage Available
Data lanes x1
Slot Designation Slot2 / X1PCIEXP1
Slot Number 1
Slot PCI-E
Slot Type PCI-E
Data lanes x4
Slot Designation Slot3 / X4PCIEXP
Slot Number 2
Slot PCI-E Gen 3 x1
Slot Type PCI-E Gen 3 x1
Data lanes x1
Slot Designation Slot4 / M2 WLAN/BT
Slot Number 3
ThanksLast edited by neroman00; 11th Sep 2019 at 09:02.
Odd that HP's specs in the PDF that I linked to mention the PCIe x16 and PCIe x4 slots but not the PCIe x1 slots. Both of the TV tuner cards are PCIe x1 so they will be fine in an x1 slot if you want to reserve the PCIe x16 and PCIe x4 slots.
You need software that is able to utilize 8 tuners for watching and recording. You might look at NextPVR, DVBViewer Pro, and SichboPVR.Ignore list: hello_hello, tried, TechLord, Snoopy329
Windows 10 and TV tuners issues
By Dencorub in forum DVB / IPTVReplies: 13Last Post: 25th Mar 2019, 10:59 -
TBS closed caption!
By Derel in forum Video Streaming DownloadingReplies: 3Last Post: 18th Feb 2019, 13:42 -
Quad HD (QHD)
By kyrcy in forum ComputerReplies: 1Last Post: 5th Feb 2018, 11:05 -
Atom Heart Mother Quad Blu-ray
By Dieu in forum Authoring (Blu-ray)Replies: 1Last Post: 27th May 2017, 13:50 -
dvd recorder with digital tuners
By chuckl in forum DVD & Blu-ray RecordersReplies: 44Last Post: 11th Dec 2015, 13:04
