Heck, I used a simple AviSource on it and had no problems at all.
Results 31 to 43 of 43
It doesn't really make sense that ffVideoSource() would have problems with a huffyuv avi. The codec is all intra-frame (every frame is a keyframe) and the container has in index pointing to every frame. I compared ffVideoSource(), LWlibavVideoSource() and AviSource() and all three delivered exactly the same frame every time, even quick on random seeking. The only difference I found was that ffVideoSource() gave YV16 output by default. The other two gave YUY2.
I suspect the OP just made some other error when he was using ffVideoSource() earlier. -
I am in no position to shed light on why it does or doesn’t work with the any given filters, but it’s now working and I’m ecstatic.
Every time I have any software set TFF. Even I know vhs is TFF.
VHS is not TFF. Analog video doesn't even have frames. It's is simply an alternating series of top and bottom fields. It's only when fields are digitized and paired into frames that it becomes TFF or BFF. The capture device/firmware determines whether the capture starts with a top field then pairs it with the next (bottom) field to produce TFF frames, or starts with a bottom field then pairs it with the next (top) field to create BFF frames.
That’s sort of what I meant...it’s captured at top field first if allowed to specify but I don’t want to get too wordy here lest I get pummeled.
I am pretty sure that the OP had a sourcefilter/decoder issue. We don't know his OS and video installations.
For example when I tried DirectShowSource (to be avoided, I know) and watched the fields (TFF) I got occasional, random glitches in the sequence. Maybe the OP's system defaulted to DSS? -
Still using AVISource here and I can't duplicate that first sample he uploaded with the dupe frames and missing frames, so maybe you're right about what you said the problem is (which I don't fully understand). With a simple QTGMC (no field order correction) I get the stuttering movement. But with SelectEven or odd after QTGMC or using FPSDivisor=2 within QTGMC, it plays smoothly at 29.97fps. I thought sure I could confirm the problem of using a single rate deinterlacer with the wrong field order, but I can't.
So I apologize to both you and Barrythecrab for claiming otherwise. I'm glad you (Sharc) solved his problem for him. -
No apologies needed, but plenty of thanks to go around!
My dxdiag is attached if anyone might find it of interest. -
QTGMC Problem
By jseo13579 in forum EditingReplies: 2Last Post: 14th Aug 2019, 09:59 -
I think this just needs QTGMC...
By pooksahib in forum Video ConversionReplies: 2Last Post: 30th May 2019, 03:12 -
Help with QTGMC?
By attackworld in forum EditingReplies: 3Last Post: 26th Nov 2018, 21:57 -
Frustrated with QTGMC
By guayabito in forum Newbie / General discussionsReplies: 19Last Post: 8th Oct 2018, 04:15 -
QTGMC error
By bakonfreek in forum Newbie / General discussionsReplies: 13Last Post: 13th Dec 2014, 22:08
