After I got done with editing my new video, How I got my name, I started exporting the video. Around the middle of exporting, my laptop crashed. It was very similar to an overheat crash. Although, my fan wasn't even close to hot. Could I get an answer why? I promised an upload and now i'm really sad...
Sincerely, Anothuor.
Run Core Temp while encoding. What kind of temperatures do you get?
https://www.alcpu.com/CoreTemp/
Also, it generally helps if you indicate what CPU you are using, what O/S, what software, what codecs, etc. -
I know my laptop fan does not go to 176 degrees, stop sending me false applications.
176 F (80 C) would not be unusual for a laptop's core temperature under heavy load.
176 C would definitely indicate a problem. But I doubt you could ever see that value in Core Temp because the computer would have crashed before temperatures got that high.
What video editor?
Usually "overheat crashes" do not occur, because CPU/GPU throttle speed with modern hardware
What do you mean by "overheat crash" ? What symptoms are you observing ? Describe them e.g. did the OS crash, editor crash ? what error messages ? BSOD ?
DVD Shrink Crashing
By koberulz in forum Newbie / General discussionsReplies: 9Last Post: 5th Mar 2019, 17:45 -
XMedia Recode 3.3.7.2.Crashing
By lostcowboy in forum Video ConversionReplies: 0Last Post: 17th Sep 2017, 02:44 -
ffmpeg.exe keeps crashing
By Randomletters in forum SVCD2DVD & VOB2MPGReplies: 14Last Post: 17th Jan 2017, 15:04 -
VobSub 2.23 crashing upon install
By kodec in forum Video ConversionReplies: 0Last Post: 7th Jan 2017, 07:11 -
Can you do this without crashing VLC?
By Adithya in forum Newbie / General discussionsReplies: 3Last Post: 29th Oct 2016, 09:31
