Is it possible for nvenc to achieve an output similar to x264 crf 15, or is it impossible because of how it prioritizes speed over quality?
Results 1 to 9 of 9
Would you recommend a cbr/vbr pass over a rate control mode setting like cqp for nvenc? If so, at what bitrate is usually recommended for, let’s say, blurays?
If you want a quality like x264 CRF 15, then you need to use a quality mode in NVENC too. You can't really do 1:1 equivalent as CRF in x264 is unique but you can try experimenting with CQP 15 in NVENC, and drop the number further until you think they are the same.
All I really want to know if it’s possible to achieve something that is visually the same as x264’s because a lot of people keep telling me that nvenc sacrifices quality and generates bigger files when I don’t have a problem with the size. You actually read my mind when you told me to try cqp15 as that was actually a setting I used before when screen recording with OBS.
You may want to look into some VMAF testing that was done recently by an Aussie Gaming Blog (I'll try and find the link).
They summarize through extensive testing that Turing's implementation of NVENC HEVC using either the 'Slow' or 'HQ' settings is Superior in terms of not only speed, BUT QUALITY ALSO, when compared to CPU/Software encoded h265 at bitrates of 8k @ 1440p....meaning that 1080p should be a piece of cake at similar.
It also had shown that Pascal 'HQ' HEVC was a near match to h265 Slow at 8k, with even Maxwell 'HQ' HEVC coming in somewhere in the h265 Medium range of perceptual quality, again, @ 1440p 8k.
Would it be fair to say that in terms of perceptual quality, 1440p 8k would be somewhere in the 6-7k range for 1080p ?Last edited by Allan74; 7th Sep 2019 at 04:50. Reason: added HEVC clarification.
X265 2PASS SLOW quality WAS achieved by NVENC HEVC (Staxrip)
By Comparison in forum Video ConversionReplies: 37Last Post: 14th Jan 2022, 03:42 -
How to achieve the quality of X264&X265 2pass slow with NVENC HEVC?STAXRIP
By Comparison in forum Video ConversionReplies: 10Last Post: 10th Jun 2020, 15:39 -
Is there a reason my NVENC encodes look better than my x264 ones?
By CursedLemon in forum Newbie / General discussionsReplies: 13Last Post: 20th Aug 2017, 01:59 -
faster ffmpeg video/audio encodes for nvenc/loudnorm ?
By hydra3333 in forum Video ConversionReplies: 1Last Post: 14th Jan 2017, 05:39 -
1080p or 720p if video quality is indistinguishable on a 19" monitor?
By JeremyBrown in forum Newbie / General discussionsReplies: 2Last Post: 28th Aug 2015, 13:30
