I've been using Avisynth 2.58 for years (I know!) and everything has always worked fine. I would edit the avs in notepad and drop it in VDub2 and it would refresh. I'm using latest Virtualdub2 and latest Avisynth+ now and it works.. when I drop the avs the first time, if I do it with the same avs again or another one, VDub just hangs up and doesn't respond. Same thing happens if I use the script editor in VD. I tried different versions of VD, including the very old ones, same thing. So I suspect it's something to do with Avisynth+, I just don't know why. Quite annoying to have to open Virtualdub again and close the old one each time I update the script. Any ideas? Thanks in advance!
Update! Solved. Problem in plugins folder, AvsFilterNet.dll was the offender.
You may try the STABLE and «official» Avisynth 2.60, or you may try the latest Avisynthpp
(no installer though, you'll have to overwrite the old DLLs with the newest ones)
https://drive.google.com/file/d/1fD3icmCBr3x3tHjFzxsr5h8Rw6nO4uZV/view"Programmers are human-shaped machines that transform alcohol into bugs." -
Thanks, 2.60 does work. But I'd rather use the plus version. Overwriting the DLL's didn't work, unfortunately. I also tried older + versions without success.
Update: it appears to be my plugins folder. Now I have to re-organize it, argh. So much junk!Problem signature:
Problem Event Name: AppHangB1
Application Name: VirtualDub.exe
Application Version: 2.0.0.0
Application Timestamp: 5d5e5b6e
Hang Signature: 437b
Hang Type: 256
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1062
Additional Hang Signature 1: 437b24935f5183d6daead8fd7fe13ca8
Additional Hang Signature 2: 0e4e
Additional Hang Signature 3: 0e4e961ab15b339ccfba2743b6b1e270
Additional Hang Signature 4: 437b
Additional Hang Signature 5: 437b24935f5183d6daead8fd7fe13ca8
Additional Hang Signature 6: 0e4e
Additional Hang Signature 7: 0e4e961ab15b339ccfba2743b6b1e270
Update 2: the problem was AvsFilterNet.dll which I had there for some reason unknown.Last edited by Chief Mouse; 6th Sep 2019 at 17:21.
Having a problem with VirtualDub2
By Bruce Banner in forum EditingReplies: 9Last Post: 19th Aug 2019, 14:19 -
Need help finding external encoders for VirtualDub2
By Bruce Banner in forum EditingReplies: 4Last Post: 11th Aug 2019, 18:10 -
Can't open an AviSynth script in VirtualDub2
By Bruce Banner in forum EditingReplies: 4Last Post: 7th Jul 2019, 19:43 -
VirtualDub2 plugins
By foldbck123 in forum Newbie / General discussionsReplies: 14Last Post: 21st Nov 2018, 03:29 -
refreshing usb ports
By vhelp in forum ComputerReplies: 6Last Post: 8th Mar 2017, 10:54
