I've just found out that ED ZD Converter does not help solve the problem as the tags which are made by it can't be seen by the player. I am not even saying that the player can't read the tags. The player just does not see them and it uses the name of the file in the player's display instead of tags. I know it's true as when I remove tags from a song then the player can see the name of the song in the format like "Мне нравится.aac" which is the exact name of the file.
Thus, there are two issues to solve.
1. To change tags from whatever they are to ID2v.3 (ID3.v1 ID3v.2.3) which can be read by the player.
2. To change the tag encoding from whatever it is to UTF-8 which I believe the player will read correctly.
Which programs will solve those two issues? Of course the best option is to have one program solving these two issues.
P.S.
What does this mean- ID2v.3 (ID3.v1 ID3v.2.3)? Which exactly tag is it as I can see three different types? Sorry to be so dumb.
Results 31 to 49 of 49
Could be your harware players player is not recognizing
- Unicode filenames (non Western text encoding)
- Tags on AAC
https://www.fiio.com/m5
Note http://fiio.me/forum.php is chinese , seems hard to get support
More info on ID3 Tags which are usually for MP3s .. Apples tag only uses part of these tags do that is a problem
https://en.wikipedia.org/wiki/ID3
Look at Non-MP3-implementation and alternatives
try these tag editors (most of these work with flac m4a and mp3s, ymmv)- mp3tag https://www.mp3tag.de/en/index.html
- tagscanner https://www.xdlab.ru/en/
- Tag & Rename (no support for AAC) http://www.softpointer.com/index.htm
Just an IDEA.. try editing the tag in APPLE ITUNES.. maybe that will work. after all it has the industry standard in aac tags that work with apple and android and windows
By the way on Android players all the aac files you uploaded play but fail when editing tag.. reporting aac format not supported.
m4a plays and tags visible. aac plays no tags... file name used
Still fiddling around with files... Transferring to windows to see any solution
Have you tried
1. updating firmware on the website? maybe they made a fix for it
2. using the email address here? http://www.fiio.me/forum.php?mod=viewthread&tid=44608&extra=page=1Last edited by teodz1984; 7th Sep 2019 at 19:56.
retagging aac in windows and transferring them to android yields a playable but non tagged file...
The torture continuesLast edited by teodz1984; 7th Sep 2019 at 20:24.
Yes, I have.
I have the latest FW and I've even posted my request in a couple of more forums with FIIO reps there. The response is the same. They promised to fix the issue in the next FW update. But no ETA given.
I've found a song in .aac format where the player reads tags but can't play the file. The song was converted from flac to aac with EZ CD Converter. The song starts with a weird sound and then stops playing.
Could anybody tell the difference between those files? Why is the player able to read the tags and can't play the first file named "Tags" and can't read the tags but able to play the file named "No tags"?
Tags can be read but file not playable https://workupload.com/file/bRFQrjru
Tags can't be read but file playable https://workupload.com/file/u2RAUwY9
If the difference is found I think that will help solve the issue.Last edited by alex5908; 8th Sep 2019 at 09:31.
both files tag and notag play on Android.. but no go on tags..
imho, fiios m5 has a wierd compatibility with aac
btw what aac flavor or settings are you using on ezcd..?Last edited by teodz1984; 9th Sep 2019 at 20:25.
Florian Mp3tag Developer
Mp3tag only supports APEv2 tags for tagging AAC files. AAC files don't have a tagging format specified, so already this is a hack.
I suggest wrapping those files in an MP4 container, so that you can make use of the tagging capabilities of this format.
This is probably the reason why taggers never supported aac files.. natively
just wondering why aren't you using m4a when site says m4a is compatible with your hardware?
chinese players don't usually respect standards .. aac and m4a standards set by apple
its a chinese player.. so unless there is an option to change text encoding in tag display.. you may be out of luck
I've posted this issue in 5 English and Russian forums but no luck. Still I am not giving up.
I will inform you about the course of actions I will take and about the outcomes.
.aac to .m4a.. possible?
By romi7519 in forum AudioReplies: 35Last Post: 14th Dec 2018, 05:45 -
Cannot join .264 and .m4a (aac) and set aspect from 704/368 to 2.35:1
By Budman1 in forum EditingReplies: 4Last Post: 28th Jan 2018, 23:28 -
Converting an AAC Mono file to AAC Stereo, higher audio bitrate?
By brightmademedia in forum AudioReplies: 2Last Post: 17th Jun 2017, 09:41 -
change m4a to aac container
By jamespoo in forum MediaReplies: 11Last Post: 7th Feb 2017, 22:15 -
Batch wrap AAC in mp4/m4a
By Kylezo in forum AudioReplies: 6Last Post: 13th Mar 2016, 03:52
