Results 1 to 30 of 49
  1. Hello everybody,
    I am trying to convert .m4a to .aac with mp4box v.8 and getting this
    "C:\Users\AS>mp4box -raw 1 in.m4a -out out.aac
    Error creating file in.m4a: Requested URL is not valid or cannot be found"
    How can I solve this issue?
  2. Just:
    mp4box -raw 1 "in.m4a"
    It should create "in_track1.aac".
  3. Originally Posted by sneaker View Post
    Just:
    Thanks for the fast response.
    I'd like to convert m4a to aac but not vice versa.
    Could you write the whole script too?
  4. I don't understand what you mean by "whole script". What is not "whole" about what I posted?
  5. mp4box only mux stuff to mp4 container..
    use converter to. transform file to aac
  6. Originally Posted by teodz1984 View Post
    What is the exact name of the program?
  7. use audacity.. easy to open and save as
  8. DECEASED
    Jun 2009
    Heaven
    Please stop posting incorrect information.
    https://sourceforge.net/p/gpac/feature-requests/54/
    P.S.: the «official» GPAC documentation suxxx very-badly Not to mention that the MP4Box command-lines switches and its help screen were written by a d0rk.
    "Programmers are human-shaped machines that transform alcohol into bugs."
  9. Originally Posted by teodz1984 View Post
    It does not open m4a files. Just wav and aif.
  10. mp4box worked for me but it does not preserve tags. Which progg does preserve tags?
  11. foobar
    dbpoweramp
    EZ CD Audio Converter
  12. Originally Posted by teodz1984 View Post
    foobar
    dbpoweramp
    I've started with EZ CD Conv. Yes, it does the job like charm. I just thought I will find something which will just change tags (and without actual converting).
  13. Originally Posted by alex5908 View Post
    I just loaded a m4a into audacity
    it imported as a ffmpeg compatible file
  14. Originally Posted by alex5908 View Post
    Hello everybody,
    Well Using the proper tool helps..
  15. Why don't you just use ffmpeg?
    ffmpeg -i input.m4a -acodec copy output.aac
    Or in a batch file onto which you can drag/drop an m4a file:
    ffmpeg -i "%~dpnx1" -acodec copy "%~dpn1.aac"
    Or a batch file that will remux all .m4a files in a folder to .aac:
    FOR %%F in (*.m4a) do (ffmpeg.exe -i "%%~dpnxF" -acodec copy "%%~dpnF.aac")
  16. Originally Posted by jagabo View Post
    Why don't you just use ffmpeg? [/CODE]
    Will that preserve the tags?
  17. Originally Posted by alex5908 View Post
    I believe it does. But I don't have any m4a files to test. Or you might have to add "-map_metadata 0" to the command line.
    ffmpeg.exe -i "%~dpnx1" -acodec copy -map_metadata 0 "%~dpn1.aac"
  18. Originally Posted by jagabo View Post
    Сould you try that?
    https://workupload.com/file/g3s3EkQD
  19. That's an AAC file. Not m4a container.
    What is the purpose of this anyways? Some Googling says it is possible to put ID3 tags into ADTS AAC (I don't know if ffmpeg can write such files) but it seems very uncommon while tagged aac-in-m4a is very common.
  20. Originally Posted by sneaker View Post
    Sorry, wrong file. Please try to convert from .m4a to .aac this one with ffmpeg. https://workupload.com/file/yQG8WaaG
    The purpose is that my player can't read .m4a files tags correctly. There's no problem with reading .aac files, though.
  21. I was able to remux to aac and copy metadata tags with the following ffmpeg command line:
    ffmpeg.exe -i input.m4a -acodec copy -write_apetag 1 output.aac
    Got a hint from here: https://trac.ffmpeg.org/ticket/2269
  22. Originally Posted by jagabo View Post
    Thanks. Windows Mediainfo can see the tag but my player does not. It just reads the song as "output.aac". No song name, no album. Nothing.
  23. Not all players support ape tags in aac. Do you have any aac files for which your player displays metadata info?
    I wasn't able to find what the "1" after the write_apetag meant. Maybe it means ape version 1. Try using 2 instead.
    <oops> No, 2 doesn't work. Program aborts with error. </oops>
  24. values 0 and 1 only acc to https://gist.github.com/tayvano/6e2d456a9897f55025e25035478a3a50feature either on or off
  25. what player are you using?
    many players usually have a hard time with aac tags. it may be a matter of finding one that works..
    what about the one converted with ezaudio converter?
  26. I tried with several Windows players. MPCBE, MPCHC, PotPlayer, KMPlayer, and SMPlayer showed the APE tags. WMP and VLC did not (though it might be because I don't know how to enable the display in those players).
  27. Originally Posted by teodz1984 View Post
    Fiio M5. It's a hardware player. Portable. Not software.
    The song tags of files converted with ezaudio converter are of no problem
  28. Originally Posted by jagabo View Post
    This one is converted from flac to aac with EZ CD Converter.
    https://workupload.com/file/rmBbBmMH
  29. Originally Posted by alex5908 View Post
    That file contains ID3 tags. I didn't see any indication that ffmpeg can write ID3 tags with the aac/adts muxer. But I tried it and it worked:
    ffmpeg.exe -i input.m4a -acodec copy -write_id3v2 1 output.aac
    The write_id3v2 flag was found in the aiff muxer docs.
  30. Originally Posted by alex5908 View Post
    Portable Fiio M5. It's a hardware player.
    Hardware players will have compatibility problems with tag support... I've seen tag support problems with AAC in Android even with Android Apps
    Android Players
