The small segment from my video is in one of my comments below
I was thinking to use nnedi3 for upscaling and mClean for denosing, but I would love to know if there are other things I could do to make it look better
Also if nnedi3 and mClean isn't good for this specific footage. Please tell me
I also mainly use Staxrip
Results 1 to 9 of 9
Last edited by SomeoneNeutral; 4th Sep 2019 at 13:33. Reason: The video is down below in one of my comments.
Yes I changed the link for a interlaced and better quality version of the video
I see your new files but I think you took an interlaced source and encoded it with x264 in progressive mode. x264 is saying interlace=0 in the metadata. So be sure to put in the command line -tff, which stands for top field first and will force x264 to encode it interlaced. Or just cut the original source (lossless ?) in Virtualdub and post it here.
Okay, sorry I'm quite new to all of this. This one should work, Here is the file you should be watching. Which is correctly interlaced
There's not a lot that can be done with that footage but I simply used QTGMC as the deinterlacer and changed the hue. I didn't crop the left or right as I forget how much is supposed to be cropped with PAL footage.
Code:dss2("C:\....\This is the one you need to click.mp4", fps=25.000).AssumeFPS(25,1) #you don't have to use dss2 qtgmc() tweak(hue=40.0, bright=-10)Last edited by KarMa; 5th Sep 2019 at 05:48. Reason: Forgot the word crop
Wow, that tweak really improved the colors in the footage. So thanks for that.
Is there anyway to get the picture maybe just a little sharper? -
Maybe adding something like.
limitedsharpenfaster(strength=200, edgemode = 2)
The attached video uses the same script as my last, just one uses the limitedsharpenfaster (Labeled Sharpened) while the other does not. It's pretty hard to do much sharpening without artifacts so this is my best attempt.
Can someone restore this file?
By coco3456 in forum RestorationReplies: 0Last Post: 5th Jan 2019, 02:47 -
Can I come to restore this video?
By ciccioschumacher in forum RestorationReplies: 120Last Post: 11th Apr 2018, 00:53 -
Use stacking (or other methds) to restore VHS footage from multiple sources
By Jellybit in forum RestorationReplies: 4Last Post: 11th Oct 2017, 18:50 -
Can someone help me restore this
By Starfx in forum RestorationReplies: 10Last Post: 13th Aug 2017, 13:33 -
Is it possible to restore this video?
By digicube in forum RestorationReplies: 9Last Post: 14th Nov 2015, 21:33
